Post by Penguin45 on Aug 15, 2020 19:39:58 GMT
I wondered when it would start. Seven months was longer than I thought it would be.... Chimney Pot by Penguin 45, on Flickr Look at that! A whopping great chimney topper. It needs stripping, straightening, soldering and shining and I've got ten days to do it in. Chimney Pot by Penguin 45, on Flickr That says: Baxendale & Co. Lead Merchants. Brass Finishers. Manchester. It was a big business according to Grace's Guide, employing 1,250 people at one time. Chimney Pot by Penguin 45, on Flickr It's solid copper. The bottom half is stripping off nicely with a large sharpened paint stripper. The stuff on the cone seems to be rather tougher. I'm having to use a really coarse disc in the DA sander to make any progress at all. There are wood remains in the hole at the top of the cone, suggesting that it had some sort of finial at some point. If I knew what the thing was actually called I might be able to find out what it actually was. Stuff I get dragged into. I don't know..... Chris.
Post by tonymark3 on Aug 15, 2020 20:14:50 GMT
Classy bit of kit,but what are you going to do with it when it’s polished?
Post by Penguin45 on Aug 15, 2020 22:59:08 GMT
Snoopy's going to take it away and put it back on top of a building. Rather him than me!
Post by Penguin45 on Aug 18, 2020 18:38:23 GMT
Got it pretty much fully stripped now. The angry grinder came out in the end. Almost certainly lead paint, so a quality dust mask was used throughout. Three of the vertical panels are pretty much straightened out - some canny panel beating gone on, as there is very restricted access from the rear. Three of the corner gussets were badly damaged and have been removed for attention. Chimney Pot by Penguin 45, on Flickr This one also improves access to sort out the damage to the base in that corner. Chimney Pot by Penguin 45, on Flickr Before. Chimney Pot by Penguin 45, on Flickr After - x 3. Chris.
Post by Penguin45 on Aug 18, 2020 20:11:17 GMT
Post by Penguin45 on Aug 19, 2020 10:10:37 GMT
Baxendale Chimney Vent by Penguin 45, on Flickr This was the last vertical section to sort. It was pretty stoved in. WIth the vanes up the inside, there was no room to get a hammer in there. I cobbled up a system of blocks and lengths of wood and managed to lever/pry/massage the dents out from the inside. Not perfect, but you've got to look closely. Maybe I've invented something. I'm going to call it Painless Dent Removal or PDR for short. Chris.
Post by snoopy11 on Aug 19, 2020 18:26:00 GMT
Looks like it’s starting to take shape
Post by Penguin45 on Aug 20, 2020 16:14:35 GMT
Baxendale Chimney Vent by Penguin 45, on Flickr I think that's about done as it's going to get. A month would have been nice. Unsolder the whole thing, get inside that top cone and deal with all the dents properly before building it up again. I'd forgotten how messy stick soldering was! Only burnt myself twice. Chris.
Post by tonymark3 on Aug 20, 2020 19:56:07 GMT
Lovely job. Only thing is it’ll go green now. Do we get photo of the installation?
Post by Penguin45 on Aug 20, 2020 23:02:14 GMT
I think that's the general idea. Allow a spot of natural verdigris to develop over time. I hope Snoopy will get a couple of pics when it goes back up. My days of clambering about on rooves are long gone.
Post by snoopy11 on Aug 21, 2020 18:32:56 GMT
Once it’s up on the roof I will put a couple of pics up
Post by Penguin45 on Aug 29, 2020 21:02:36 GMT
Twins are up for Bang Koliday. Alex (Twin #2) has come in his Matiz replacement - a Toyota Yaris. Low mileage, FSH, 1 owner, bargain price are the plus points. 20 years old and appalling paint is the downside. For once, there was some forward planning, so suitable paint supplies have been laid in, as well as service parts. Possibly one of the easiest services I've ever done - I got Alex to do it! Seriously, very simple. Even with walking Alex through the job, it was done in 50 minutes. Paintwork. Toyota Yaris by Penguin 45, on Flickr Dent. Hammerite. Toyota Yaris by Penguin 45, on Flickr Toyota Yaris by Penguin 45, on Flickr Toyota Yaris by Penguin 45, on Flickr Toyota Yaris by Penguin 45, on Flickr Scratches. God knows what's happened to the clearcoat. Anyway, a short while later. Toyota Yaris by Penguin 45, on Flickr Toyota Yaris by Penguin 45, on Flickr Flatting back under way. Toyota Yaris by Penguin 45, on Flickr Primer going on. Toyota Yaris by Penguin 45, on Flickr Colour and clearcoat. No flatting yet. Toyota Yaris by Penguin 45, on Flickr Meanwhile, Alex had been following the process and did this "A" pillar himself. We then spent about two hours flatting, compounding and polishing and the results were rather mixed to be honest. The conventional wisdom is three coats of primer, then flat before applying base coat. DO NOT FLAT THE BASECOAT. So I didn't, then three coats of clearcoat and flat that. So I did. Results are variable. Bumper came up lovely. Wing has a great shine, but looks rough, passenger door is better but has rough looking areas. The clear coat is lovely and smooth,so the problem is with the base coat. We're going to do the back half tomorrow, and I will try gently flatting the basecoat before the clearcoat. Got to be the answer - it's a 7/10 job at the moment. Alex is actually pretty pleased, as it's all the same green and shiny. Definitely an improvement. Chris.
Post by tonymark3 on Aug 30, 2020 12:12:22 GMT
Post by Penguin45 on Aug 30, 2020 21:49:01 GMT
Cheers Tony. This is my first major go with clear coat, so it's a bit of a learning curve. Rather more technical than blowing some over the ROstyles. Did the back end today. It's rather better, but far from pefect. Toyota Yaris by Penguin 45, on Flickr Toyota Yaris by Penguin 45, on Flickr Toyota Yaris by Penguin 45, on Flickr Made a point of flatting (gently - 1200 grit, wet) the basecoat and it has made a significant difference. Last picture is after two coats of clearcoat and before any cutting and buffing. Definitely more even. The "A" post got done on this side as well. Anyway, it's all been compounded and severely polished and looks a whole heap better. Alex is pretty happy that it's all one colour and the crazed finish has gone, so I'll chalk it up as a success. Partly. Chris.
Post by Penguin45 on Sept 9, 2020 21:01:01 GMT
This turned up in the garage today. Bobber by Penguin 45, on Flickr Appears to have a deficit in the wheel department to the tune of two. It's a "bitza" bobber. The owner's dropped it and knocked the gear selector clean off. There's also a list of other things to be done, most notably that oil cooler needs proper mounts making and the wiring sorting. Looking at what's there, I think that's going to be "start again". Bobber by Penguin 45, on Flickr Substantial bit of tubing attached to frame. You can see the scratches along the engine casing from when he dropped it. Bobber by Penguin 45, on Flickr Selector attached to tube. Needs new link bar back to the gearbox. Anyway that should keep me amused for a few days. Beats polishing.Oh, MrsP has had complete conniptions and says I'm not to ride it around the block, even for "testing purposes". Chris.
