Post by dave1800 on Mar 9, 2018 2:07:29 GMT
It does sound as though there is a vapour lock problem. The could be being caused by not having the correct crankcase ventilation and the wrong mixture as a probably consequence leading to the engine running hotter than normal. Retarded ignition - even a few degrees will result in the exhaust manifold running much hotter and that is one of the main culprits.
Fitting the phenolic carb spacer will help, but I note that despite many mods made to Oz cars to suit the climate and roads I believe the aluminium carb spacer was retained and the service bulletins noted vapour lock was not an issue - at least with the leaded fuel.
When you fit the new oil filler cap and heat-shield, set the mixture and ignition timing correctly, if you still have the problem I suggest:
Check the routing of all the fuel pipes in the engine bay to ensure they run well clear of the hot exhaust Check the fuel pump is holding pressure as previously discussed, does your vacuum gauge have low pressure fuel pump scale - some were combined. If the pump is weak it may not be able to overcome any vapour in the inlet or the outlet pipes. The fuel pump (mechanical) is mounted to the block with a phenolic spacer, difficult to see but does this appear original?
Fit a fuel filter in line
Ensure the float chamber and nylon tube attached to the jet is thoroughly clean. The tube has a very narrow diameter and any tiny bits of debris can allow fuel bubbles to block the flow.
Did your engine cut out with the bonnet open or closed?
Post by paddymk2 on Mar 9, 2018 14:19:39 GMT
Thanks for that info The engine cut out with the bonnet open. I'd only noticed it really cutting out with the bonnet open and fiddling around the engine. but previously I noticed it very difficult to restart when hot. When you say set the timing correctly, did you mean just set the static timing? (And leave the vacuum timing method? I thought that was kind of neat, and thr vacuum seemed to pull a lot more. Still need to check but I think I've turned the distributor about 10 more degrees anticlockwise so it should be more advanced.) Regarding setting the mixture, its a wee bit difficult if the engine stumbles while warming up. So my starting point was 2 full turn down from the jet all the way up to the piston shoulder. I had look at the spark plugs last night - they're black and sooty (not right) but they don't appear as if its running lean (although starting it up in the garage is different than a proper run.) Yes the vacuum gauge has a low pressure side. And yes I should fit a filter. And have another look inside the float valve etc. Its possible things have been moved around the fuel lines - how far away are they supposed to be clear from the exhaust manifold? (looks to be about 2-3 inches.) I didn't notice the phenolic block on the pump - waiting for the daylight on Sat to see... The heat shield is very make-shift , literally a thick sheet of aluminium (0.2mm) folded to cover the fuel pump fuel lines, float and pressure regulator - but letting some air flow around. I plan to check its effectiveness with a thermocouple and implement if its helping. Thanks again Paddy
Post by tommydp on Mar 9, 2018 15:24:12 GMT
Moving the distributor anti clockwise will retard the ignition.
The plugs will become black and sooty at idle, even at the correct setting.
This must be a fuelling issue. I would remove the carburettor chamber and piston, watch the needle...., and establish where the fuel level is in the jet using a depth indicator. It should be around 3-4 mm below the bridge. With the float chamber full, pull down the jet until it's level with the fuel. Then measure from bridge to top of jet.
What happens to the fuel level in the jet when it stalls? My guess is fuel is either flooding out of the jet, or you have no or little fuel in the jet which would point to a float or fuel supply problem. I have started establishing where the fuel is in the jet, rather than fiddling with measuring float gap. I find it far more accurate.
When you have got the fuel level right, set the timing to 9 degress BTDC static, turn the mixture nut 12 flats down and idle screw 1.5 turns in from closed throttle. Fine tune from there.
Good luck.
Post by Penguin45 on Mar 9, 2018 15:45:04 GMT
Good stuff from Tommy. Both my cars use electric pumps back by the tank. I have had no joy with the mechanical ones over the years. It means that I can run the fuel line up under the master cylinders, across the back of the displacer tube and loop back from under the servo. The fuel line is never closer than six inches to the exhaust at any point. I don't have any fuelling problems - mine ar all ignition related. Chris.
Post by paddymk2 on Mar 9, 2018 23:53:19 GMT
Moving the distributor anti clockwise will retard the ignition. Oh Sorry - when I said anticlockwise I meant I turned it clockwise(!) I blame that on it being so late.
Post by dave1800 on Mar 10, 2018 2:28:57 GMT
Yes, thanks Tommy I agree everything is pointing to a fuelling issue, too much or too little. The electric fuel pump mounted at the rear not only runs cool but pushes fuel instead of sucking the length of the car which is a great advantage if there are vapour bubbles in the line as they are compresed. Paddy, the ignition timing should be set initially at the static setting. This is slightly different from the UK spec being 10 degrees not 9 (but a not critical difference). Mk11 Oz cars had slightly lower CR 8.8:1 vs 9.0:1. You can also check that the mechanical advance works by using a timing light with the vacuum advance pipe disconnected and plugged to avoid air leak into the carb. You should also check the vacuum advance works by sucking on the pipe to make sure the diaphragm has not split and watch the distributor plate moving smoothly. If it doesn't work the engine will be retarded under light to medium load and the exhaust manifold run hotter and if the diaphragm is split it will leak air and upset the mixture setting. Tony Cripps published a series of excellent Newsletters that are on the Oz site I linked earlier. He noted in Newsletter No 3 that there were errors in some of the Oz workshop manuals regarding the distributors and confusion between distributor degrees and crankshaft degrees which may have resulted in some cars being wrongly timed. Well worth a read, the correct figures are presented in the technical service bulletins. The correct info for testing with the timing light for an Oz Mk11 care is: Distributor = 629410797B (stamped on side plate) part no AYH 0576 Type 29D (UK = 25D) Engine RPM / Advance 700 rpm 11 deg 1200 rpm 14 deg 2000 rpm 21 deg 2600 rpm 26 deg 3800 rpm 30 deg 5000 rpm 34 deg 5600 rpm 34 deg NOTE: These figures include the static advance of 10 degrees BTDC. (I wouldn't advise checking beyond 2,600rpm with no load on the engine ie on a dyno.) Vacuum adv 11 degrees @ 15" Hg David Good stuff from Tommy. Both my cars use electric pumps back by the tank. I have had no joy with the mechanical ones over the years. It means that I can run the fuel line up under the master cylinders, across the back of the displacer tube and loop back from under the servo. The fuel line is never closer than six inches to the exhaust at any point. I don't have any fuelling problems - mine ar all ignition related. Chris.
Post by paddymk2 on Mar 11, 2018 9:57:45 GMT
I started off with a new coil to take that out of the equation. Re-did the static timing. When I turned the engine on and let it warm up the timing (by strobe) was about 18 degrees at 800rpm The vacuum was only about 10 inches Hg. The engine was getting about the N temp. I turned the ignition off - and car would not restart. I checked the carby bowl - there was plenty of petrol. Let it cool for 15min; It restarted. I adjusted the distributor anticlockwise a bit but the engine sounded worse and the vacuum reduced. So I turned it back to roughly where I'd started. I reduced the RPM to 700 and checked the angle - it was about 12-14 degrees. (this is all with vacuum disconnected from the distributor.) I noticed there was some black smoke at the exhaust. So I wound the mixture nut up 2 flats to lean. It may have been better (less smoke). It seemed to keep running but the temp gauge was creeping above the N indicator. The fact that it didn't cut out is probably due to timing / ratio changes and my heat shield arrangement. It wasn't a very long run but seemed better. I didn't get to wind up the RPMs to high values. If it operates the same in the morning I'll pull the car out and check the timing at 2600RPM. I'm a bit disappointed by the level of vacuum and might then have another tweak on the distributor. The mixture ratio setting (and all the rest) have been with the air filter and the adapter plate to the carby off, I'd expect putting the filter on will restrict the airflow and make the ratio a bit richer. Thanks for the advice(s) guys Paddy
Post by dave1800 on Mar 11, 2018 11:06:23 GMT
It looks as though you may have an ignition timing and a fuelling problem. The latter is probably where to start.
Fuelling
The black smoke may have been an indicator that the float valve isn't seating and causing the engine to flood rather than incorrect jet adjustment.
If this is the case, by weakening the mixture you may have caused the temperature to creep up by creating a situation where the engine was running weak and intermittently flooding. If you take off the float chamber lid, turn it so the float is uppermost and blow into the fuel inlet pipe you can check if it is sealing and / or sticking. The w/s manual shows how to check the correct height using a 3/16" (5 mm) drill bit as a spacer between the float and lid - you or may not have an adjustable float. If the float has any fuel inside it then it must be replaced as it will flood if the float is punctured (modern fuels can damage the floats and Burlen make unsinkable floats now.)It's easy to dismantle and check the valve and check it is not worn and is seating properly and is thoroughly clean.
Ignition
There's something very odd with your ignition timing results when changing the idle from 700 to 800 rpm you should only have seen an increase of about 1.5 degrees of advance not 4-5 which I do not understand - it could be a weak spring in the distributor or jitter /slack in the timing gear drive train. Does the timing light give a clear steady indication or does it jump around? What you will need to determine is whether the timing marks on the pulley are accurate and the maximum ignition advance doesn't exceed 27-28 degrees at 3000 rpm - I wouldn't suggest going to 34 degrees at 5000 rpm lying under the car. As you know exceeding the max advance at high rpm and load is THE engine killer.
Vacuum As you earlier noted a higher and more reasonable vacuum with more ignition advance I suspect there could be an issue with the timing mark on the pulley - I assume the pulley is tight on the crankshaft and the Woodruff (locating) keys are intact -can you feel any play by rotating the pulley? The other consideration is whether the valve timing is correct as this can lead to low vacuum.
At this stage I think it better to be 100% with the fuelling/valve clearances/air leak checks and not be tempted to advance the ignition to regain vacuum.
We discussed how to check the accuracy of the timing marks in Tommy's thread and more recently in Chris' and the valve timing can be checked at the same time but at this stage can you look at the crankshaft pulley to see if there is any movement on the crank and if the rubber between the inner and outer sections is secure / distorted.
Finally, double check your readings and if possible check your timing light and vacuum gauge against a known good source if you can.
Post by paddymk2 on Mar 11, 2018 23:33:36 GMT
Hi Dave Regarding the float valve checks (1) Float valve is not blocked or sticking (is closing off and opening up with valve operation, freely operating and clean) (2) Float is not adjustable (3) No fuel inside the float
Now to check the timing again. Back soon
Post by paddymk2 on Mar 12, 2018 2:31:38 GMT
Pulled of the wheel to make it faster to have a look The car started easily - perhaps fast, not sure if opening and blowing through float valve may have done something? Waited till it warmed up Idle was 700-800 rpm Checked advance degrees 800 about 12 1000 about 14 2000 about 20 That looks about right. Still a bit of smoke at the tail pipe and the temp at top of N. Will put it back together and go for short run. Best regards Paddy
Post by dave1800 on Mar 12, 2018 6:46:19 GMT
I agree the distributor timing advance looks about right, but you still need to resolve the low vacuum issue. Assuming the gauge is OK and as you obtained a higher reading by advancing the ignition that would seem to support the accuracy of the gauge reading but any opportunity to check it against a known source would be valuable. There can be several reasons for a steady vacuum reading as low as 10" Hg. a) an air leak -inlet manifold to cylinder head, PCV, servo take off etc. Check with soapy water or starter fluid spray (with care). Check the tightness of the manifold to cylinder head bolts - these can loosen b) retarded ignition timing c) delayed valve timing See scenario 10 Vacuum gaugea) is the easiest to check. I suggest blocking off the servo pipe after your vacuum gauge "T" before the servo. An air leak will upset the mixture adjustment. If you compensate for an air leak at idle the rest of the range will be too rich. An air leak is greatest at high vacuum ie at idle which can cause the engine to run hot. b) your advance test:rpm looks fine but if the pulley marks are incorrect it could still be retarded throughout the range and run hot. A visual check of the pulley for damage to the rubber joining the inner and outer sections and a check for any rotational play should be done. c) delayed valve timing is hopefully unlikely but it is just feasible the valve timing could have been set incorrectly if it has been rebuilt or a non original timing chain has been used. At this stage I would opt for (a) but it would be helpful to fit an in line fuel filter and to let us know what is the advance required to obtain 18-20" Hg vacuum at idle as this could throw light on whether the valve timing is OK. We can then take it from there by taking some measurements if necessary. David Pulled of the wheel to make it faster to have a look The car started easily - perhaps fast, not sure if opening and blowing through float valve may have done something? Waited till it warmed up Idle was 700-800 rpm Checked advance degrees 800 about 12 1000 about 14 2000 about 20 That looks about right. Still a bit of smoke at the tail pipe and the temp at top of N. Will put it back together and go for short run. Best regards Paddy
Post by dave1800 on Mar 12, 2018 10:13:33 GMT
The Oz cars do in fact have a lower idle but I would suggest keeping it at around 700 at least until this problem is resolved (it will be!)
Post by paddymk2 on Mar 12, 2018 12:00:16 GMT
Hi Dave, As the car warmed up this afternoon the vacuum came up to about 15 Hg Which is not brilliant but not bad. (when I first connected it up the vacuum was down at 5) I went out for a run around the streets. I live on a steep hill and previously have felt the car was going to stall coming up (so I have to wind my way up the back streets). But today it drove up fine - that's a bonus. I had disconnected the brake booster and put the vacuum hose directly onto the brass fitting on the manifold (I've reconnected the brakes.) It could still be leaking - as the rubber tube was matched to a couple of inches of flexible PVC tubing and that can distort when hot.
Regarding the general overheating -I'm just wondering perhaps its not the fuel or timing, perhaps its something like leak stop in the cooling or oil system? I did run water from a hose through the engine cooling to flush it (change the hoses, water pump, get the radiator recored etc.) But you never know what's been done in the past - especially those leak stop things.
Regards Paddy
Post by dave1800 on Mar 12, 2018 12:16:14 GMT
Hi Paddy
That's really encouraging. I'm having a think about what could possibly cause the vacuum to increase from 5 to 15" Hg as it warmed up. It should stay reasonably constant. I guess the first thing is to try and get a really good vacuum gauge connection.
I would have thought that the radiator being re-cored should have removed any leak stop from the equation. These engines set up properly have bags of low down torque and will climb mountains as Tommy can vouch.
Anyone have thoughts about why the manifold vacuum should increase as the engine warms up? (I assume you didn't have the choke on which partly opens the throttle for the fast idle?)
Post by paddymk2 on Mar 12, 2018 21:23:47 GMT
Hi Dave I'll check the gauge and have a look at the choke setting.
Yes I agree the radiator should be clean after recoring.
You mentioned earlier a small water leak, being enough to reduce the pressure and cooling efficiency. While putting the grill on yesterday I notice a bit of water seeping at the welsh plugs (green - coolant colour.) The water level in the radiator is good.
Regards Paddy
