Post by Penguin45 on Apr 9, 2014 23:04:48 GMT
Good, very good. I do like the jacking point construct. If you've kept the templates, you could be a popular man! That's the sort of panel people will need to construct in the future.
Post by bullyboy on Apr 10, 2014 6:35:43 GMT
Good, very good. I do like the jacking point construct. If you've kept the templates, you could be a popular man! That's the sort of panel people will need to construct in the future. Chris. Hi Chris Never thought of that i may knock something together for future and a method statement. Paul
Post by dave1800 on Apr 10, 2014 10:41:23 GMT
Maybe we need to think about setting up a sub section to keep the info in one easily found location? Indianajones servo bracket, your jacking points etc. Really helpful photos; hopefully the other side will be easier. Regards David Good, very good. I do like the jacking point construct. If you've kept the templates, you could be a popular man! That's the sort of panel people will need to construct in the future. Chris. Hi Chris Never thought of that i may knock something together for future and a method statement. Paul
Post by bullyboy on Apr 10, 2014 11:16:17 GMT
Maybe we need to think about setting up a sub section to keep the info in one easily found location? Indianajones servo bracket, your jacking points etc. Really helpful photos; hopefully the other side will be easier. Regards David Hi Chris Never thought of that i may knock something together for future and a method statement. Paul Yes i agree it would be useful As i also have the dash board modifications i did when i was running the car The other side will be easier as i have purchase a full new membrane so i can chop that up easier Paul
Post by bullyboy on May 8, 2014 7:04:30 GMT
Hi Long time and slow progress, here's an update Firstly i thought i would tidy up a bit , didn't realize how much has been cut out new patch repair before and After bulk head ready to be plated, pattern made when the sill is finally secured sill ready for welding zinc sprayed all prep work done hopefully to get the car back on its wheels by the end of the month More to follow PAUL
Post by bullyboy on Jun 3, 2014 11:33:57 GMT
Post by dave1800 on Jun 4, 2014 10:25:19 GMT
Paul Good to see you are progressing well and it's coming together. Thanks for the tip, I guess we are all guilty of not taking adequate precautions at times, glad to read you have recovered it could have been serious. David A little progress there for you all, just a tip when grinding please wear goggle not glasses as i spent 3 hrs in hospital yesterday after a bit flew up inside my glasses and into my eye, all sorted now but very painful and uncomfortable for a while. Paul
Post by bullyboy on Jul 22, 2014 11:04:21 GMT
Post by Penguin45 on Jul 22, 2014 20:51:35 GMT
Any progress is good progress, Paul!
Post by dave1800 on Jul 23, 2014 1:58:23 GMT
That looks like a lot of progress to me! Thanks Paul for the detailed photos regards David Any progress is good progress, Paul! Chris.
Post by bullyboy on Jul 24, 2014 6:52:49 GMT
Hi Chris I hope the photos help, its always good to see things before you embark on projects. Just a question does anybody know of a trustworthy company to do my cylinder head in the north west, it needs the unleaded treatment. At the risk of starting the age old debate of should you or should you not get hardened seats. I need it doing as it looks like the valves have started to recede into the seats already. Paul That looks like a lot of progress to me! Thanks Paul for the detailed photos regards David Any progress is good progress, Paul! Chris.
Post by bullyboy on Dec 22, 2014 15:17:37 GMT
Hi All Its been a while since my last update so may be quite a picture heavy post but i hope you enjoy it as its been hard demoralizing work, the further you investigate the more comes to light so here we go Front crossmember measured and tacked in Further work at the front Now to the rear wheel arch more nasties found undressed repair this is what £50 gets you, rear wheel arch and inner arch, spot weld been drilled out inner arch useable outer arch ready to work on part of an old front wing to be used, to rebuild the rear wing rear wing joggle ready to fit rear inner wing being strengthened not easy lying on you back lower part of rear inner dress up started more work has been done in this area i will post photos after Xmas, doesn't look like much but it sure burns up the hours. Still working on the car beening sent to spray Feb/March time, rebuilt for the new show season Merry Xmas and a Happy New Year to all Paul
Post by bullyboy on Jan 20, 2015 7:53:39 GMT
Post by indianajones on Jan 20, 2015 8:23:50 GMT
Most impressive!
Post by andrewa on Jan 20, 2015 12:06:55 GMT
Wow - brings back happy memories/nightmares! Good luck with the paint deadline...Feb/March will come round awful quickly! Cheers Andrew
