Post by andrewa on Mar 14, 2017 17:42:57 GMT
Thanks Paul appreciate it!
Post by bullyboy on Mar 21, 2017 12:46:42 GMT
Post by Penguin45 on Mar 21, 2017 18:16:13 GMT
Great progress, Paul.
Where did you get the vent tubing? He says, having just spent rather more than he wanted to on some which might just do the job.
Post by bullyboy on Mar 21, 2017 19:08:37 GMT
Great progress, Paul. Where did you get the vent tubing? He says, having just spent rather more than he wanted to on some which might just do the job.Chris. We use it at work for extract systems more commercial than domestic not than cheap but these are off cuts 100mm dia heading for the bin Paul
Post by andrewa on Mar 21, 2017 22:18:00 GMT
Post by bullyboy on Mar 22, 2017 12:21:42 GMT
Post by bullyboy on May 8, 2017 11:32:41 GMT
Hi All Just had an update from the garage, after an major issue with the bleeding of the brakes, a new master cylinder curtesy of Tony fitted and is now getting MOT'D as i type, fingers crossed. Then back to the garage for some final finishing and hopefully back for the weekend.
Happy Days Paul
Post by dave1800 on May 8, 2017 13:12:46 GMT
Well done, I hope it passes! I've found bleeding the brakes does find any bad /soft seals in the master cylinder, I guess because it is the only time the piston travels the full throw.
Post by bullyboy on May 8, 2017 17:02:59 GMT
Well done, I hope it passes! I've found bleeding the brakes does find any bad /soft seals in the master cylinder, I guess because it is the only time the piston travels the full throw. David Yes but I had it refurbished obviously not that well Paul
Post by faulks on May 8, 2017 19:19:00 GMT
Judging from the dvla, it looks like a perfect pass A good job, well jobbed!
Post by Penguin45 on May 8, 2017 19:46:46 GMT
oh, very well done.
Post by dave1800 on May 9, 2017 5:01:32 GMT
Have you tried to ascertain the problem? Were the seals new or nos for example?
[/quote]Yes but I had it refurbished obviously not that well Paul [/quote]
Post by peppib on May 9, 2017 6:59:50 GMT
Well done. The car looks fantastic
Post by bullyboy on May 9, 2017 7:06:16 GMT
Judging from the dvla, it looks like a perfect pass A good job, well jobbed! Oh thats good news i never thought of that looking on DVLA, i was expecting a call from the garage but they are a bit slow at getting anything donE, never mind a quick phone call or message Dave i haven't got the old cylinder back yet but when i do i will look into why it failed as it was suppose to have been relined and sealed at quite a price too, but the garage man noticed that the connecting shaft had been previously welded back together and he suggests it wasn't pushing straight, which when i looked at it i agreed it had been welded and his threory may be right, but it worked when i was driving it. Perhaps i put the connecting rod in upside down, i know it shouldn't matter but may be it did. Any way when i get the master cylinder back i will post any findings Regards Paul
Post by andrewa on May 9, 2017 12:09:31 GMT
And a couple of piccies of her/him in all her/him roadworthy glory would be lovely to see! Well done btw!
