Post by Penguin45 on Jun 26, 2020 12:09:01 GMT
Look what that TonyMkIII's made me do..... VOF707J by Penguin 45, on Flickr VOF707J by Penguin 45, on Flickr VOF707J by Penguin 45, on Flickr VOF707J by Penguin 45, on Flickr This is the door that didn't need any work at all first time round, so I suppose it's due. New door removal technique worked a treat. No.4 Philips impact bit, 12" extension and windy gun. Removal time - 3 minutes. More later. C
Post by tonymark3 on Jun 26, 2020 14:40:21 GMT
Well done. Best tool I bought was impact driver. Can’t get those doors off without. Got a deep socket for the swivels. God how easy. in the old days I ended up using Stilsons.
Post by Penguin45 on Jun 26, 2020 19:18:54 GMT
Stilsons? It'll be a Mole Grip confession next. Most of the way there with this door. VOF707J by Penguin 45, on Flickr VOF707J by Penguin 45, on Flickr Inner flanges cut away and replaced. Round patch welded home. VOF707J by Penguin 45, on Flickr Back end done, bottom edge flipped and flattened. I'll sort out the big one tomorrow. VOF707J by Penguin 45, on Flickr Hadn't thought of this - folder on the front and put the guillotine on the other way round allowing both to be used for the job. Works very well. Chris.
Post by tonymark3 on Jun 26, 2020 19:50:24 GMT
Cracking job. Re the Mole grips, of course. There’s always the lump hammer and cold chisel. Skint then, whatever came to hand. Socket set I could afford couldn’t take too much welly. Tony S
Post by Penguin45 on Jun 27, 2020 11:41:54 GMT
Cheers Tony. This mornings' efforts. VOF707J by Penguin 45, on Flickr Tacked home. VOF707J by Penguin 45, on Flickr Some considerable time later. Despite doing this dot-by-dot, cooling as I went, there is quite a dip above the repair panel. Time to break out the filler. See you Tuesday... C.
Post by tonymark3 on Jun 27, 2020 15:00:03 GMT
Looking good. one of my door skins has always had a lot of flex. Ended up with reinforcing strip inside the skin to stop it. Tony S
Post by Penguin45 on Jun 28, 2020 16:14:21 GMT
quite a dip above the repair panel. Straight as a dog's back leg more like. Look at this. VOF707J by Penguin 45, on Flickr It's flat with a nice line to it now and none of that is particularly thick. Meh. VOF707J by Penguin 45, on Flickr New filler used for the first time. Very easy to work with. Approved. Chris.
Post by Penguin45 on Jul 3, 2020 17:26:59 GMT
Post by tonymark3 on Jul 4, 2020 20:00:33 GMT
Looking good. Whatever I try to clean my red vinyl seats with, they still look grubby! Tony S
Post by snoopy11 on Jul 5, 2020 8:53:16 GMT
Cleaning and polishing
Has the move to Lancashire gone to your head.
Post by Penguin45 on Jul 6, 2020 16:12:51 GMT
So, I'll just leave these here then.... VOF707J by Penguin 45, on Flickr VOF707J by Penguin 45, on Flickr VOF707J by Penguin 45, on Flickr Tony - I think scrubbing the vinyl on a hard surface is what made the difference. I've had several goes at the seats in this one with poor results. Chris.
Post by tonymark3 on Jul 6, 2020 17:00:55 GMT
Once you start cleaning and polishing it’s a slippery slope.............. Tony S
Post by Penguin45 on Jul 9, 2020 17:34:28 GMT
Back door done. Another patch along the bottom edge, bottom half painted. VOF707J by Penguin 45, on Flickr I'll get started on the sill and rear arch tomorrow. C.
Post by Penguin45 on Jul 10, 2020 14:05:41 GMT
Post by tonymark3 on Jul 10, 2020 15:00:28 GMT
Looking good. What paint do you use? Tony S
