Post by dave1800 on Feb 14, 2015 1:29:09 GMT
I guess it's lucky you found the door David Pictures tomorrow when MrsP tells me where I've put my camera. Chris.
Post by Penguin45 on Feb 14, 2015 12:42:37 GMT
Seemingly my camera is in college. Doh! Have some camera phone pics: Not the greatest quality, but you can see the problems. Going to have a bite of lunch then start cutting. Chris.
Post by Penguin45 on Feb 14, 2015 20:37:56 GMT
And cut I did...... Bottom 2½" inches of the door skin cut off. Had to get this as straight as possible - it's pretty good. Corners and bottom edge repaired. Very similar work to the first one I did; just the outer skin is much worse. I'll see if I can make the new panel tomorrow. Three doors fitted. Chris.
Post by Penguin45 on Feb 15, 2015 20:50:47 GMT
Made up the repair panel for the door. Very patient job. Great deal of accuracy and precision required to get it "just so". The blank require flanges around three sides. It's 34" long. My folder is 26" long. So much for this afternoon's entertainment. I could fold it up in five minutes on the big folder at college, except we're now on half term. Then I could photograph it. With my camera....... which is at college...... which is shut.......
It's a conspiracy I tell you.
Post by dave1800 on Feb 16, 2015 1:41:32 GMT
...and the cold weather is part of the conspiracy too . David I could fold it up in five minutes on the big folder at college, except we're now on half term. Then I could photograph it. With my camera....... which is at college...... which is shut....... It's a conspiracy I tell you. Chris.
Post by Penguin45 on Feb 16, 2015 20:10:43 GMT
which is at college...... which is shut....... But - the admin staff are all in. Collected camera, bent up the flanges on the door skin panel. There - that's what the bottom of the door frame really looks like. Repair panel. Tacked home. Butt welded right across. And flatted back. This is actually the worst bit of welding I've done in ages. This sort of join you do in little short bursts and immediately blast with the high pressure air gun to prevent the heat spreading through the panel. Even allowing for this and taking well over an hour to make the joint, it's distorted all over the place. Rather disappointed. I've knocked it all down flattish and will no doubt have to apply filler to straighten it all out. Chris.
Post by Penguin45 on Feb 22, 2015 23:54:52 GMT
The door is now done. I kept count on time this time - 20 hours to fill and flat the door to a suitable standard. It might have been quicker to cut the repair panel out and do it again. I bought an 18" long board-sanding block which speeded things up in the end. Should have bought one ages ago.
As you'll probably understand, not a lot else got done this week......
Post by dave1800 on Feb 23, 2015 0:27:26 GMT
That's avery interesting statistic nd no doubt will encourage others who wonder why bodywork takes them so long. Guess you are tired? David The door is now done. I kept count on time this time - 20 hours to fill and flat the door to a suitable standard. Chris.
Post by andrewa on Feb 23, 2015 13:20:02 GMT
Now I understand why my bill was what it was! Keep going! But don't over-do it too much! Cheers Andrew
Post by Penguin45 on Feb 23, 2015 17:09:59 GMT
I haven't really kept a record of the hours for the project as a whole, but this interested me as it was going badly wrong!
It panned out as follows:
Strip door and cut away lower door skin - 1 hr. Cut away rust from door frame, make repair panels and weld home - 2½ hrs Make door skin repair panel and weld home in short bursts - 3 hrs. Dress welds, fill and flat to a presentable condition - 20 hrs.
Total: 26½ hours.
To be fair, the filler business took far too long. I don't really like using the stuff and have poor aptitude, so it could have been done better and faster. Still, it gives you an idea of where the time goes.
Post by indianajones on Feb 24, 2015 18:58:37 GMT
Certainly explains the cost of rust repairs at the shop!
Post by Penguin45 on Feb 27, 2015 0:25:49 GMT
Honestly, Indy, you just don't realise where the time is going. Anyway, door 4 is back on the car, so that's a full set. Tomorrow I'll fetch the bonnet. I do know where it's lurking. Chris.
Post by indianajones on Feb 27, 2015 9:37:56 GMT
Excellent news _b
Post by Penguin45 on Feb 27, 2015 17:03:13 GMT
Post by andrewa on Feb 27, 2015 18:15:11 GMT
Good call!
