Post by peppib on Aug 9, 2016 9:51:59 GMT
I have owned this car for coming up to 11 years. The only welding ever needed was new rear inner sills about 6 or 7 years ago. In March she flew through her MOT with no advisories, but it was noted that the waxoil was getting thin. Took her back to the same garage this morning and the tester was horrified to find this Untitled Untitled Untitled UntitledCan't believe 4 months can make so much difference Dave
Post by Penguin45 on Aug 9, 2016 10:46:24 GMT
Both sides? Day trip to Yeadon if you're up for it.
Post by dave1800 on Aug 9, 2016 10:51:48 GMT
So sorry to see the rot. It is surprising that it seemed to happen so suddenly. All I can think is that the metal had corroded leaving a thin outer skin intact at the time of the MOT. I have experienced what I think is a form of "sacrficial" corrosion where surrounding areas were protected with lots of Waxoyl but a dry patch rusted very rapidly. It is probably worth topping up the insides of the sills once a year. I hope it doesn't extend too far. A bit late now but checking an maybe opening up the drain holes is worthwhile. regards David I have owned this car for coming up to 11 years. The only welding ever needed was new rear inner sills about 6 or 7 years ago. In March she flew through her MOT with no advisories, but it was noted that the waxoil was getting thin. Took her back to the same garage this morning and the tester was horrified to find this Untitled Untitled Untitled UntitledCan't believe 4 months can make so much difference Dave
Post by indianajones on Aug 9, 2016 11:16:52 GMT
Woah! That looks a bit nasty, hope you get it all sorted soon mate.
UMO 406G
Aug 9, 2016 11:20:51 GMT
Post by peppib on Aug 9, 2016 11:20:51 GMT
Both sides? Day trip to Yeadon if you're up for it. Chris. Front and back both sides Chris I have a mate who will follow me down and bring me home if you need the car for more than a day Just let me know when Dave
Post by snoopy11 on Aug 9, 2016 19:17:34 GMT
Both sides? Day trip to Yeadon if you're up for it. Chris. That looks like a bundle of fun. If you want some help (read as someone to hinder you and take the p1&$) give me a call.
Post by Penguin45 on Aug 9, 2016 22:51:06 GMT
That looks like a bundle of fun. If you want some help (read as someone to hinder you and take the p1&$) give me a call. Noted . I hope it's a cut out and cover job, in which case it can be knocked off quite quickly, but really, who knows? I've got another 'crab coming in on the 22nd, so it needs to be sorted a bit sharpish. Chris.
Post by peppib on Aug 10, 2016 7:33:16 GMT
Snoopy - you may be required to mop Chris's brow (or, more likely, dry his tears when he starts poking with his screwdriver! ) I can't even reach the floor nowadays
Post by bullyboy on Aug 12, 2016 14:56:40 GMT
I feel your pain
Post by peppib on Aug 12, 2016 19:31:52 GMT
Bullyboy - thanks, but it will be Chris feeling the pain when he tackles the repairs!!
Hope it makes it safely to him without losing anything - wheel, suspension, driver disappearing through the floor!
Post by peppib on Aug 17, 2016 18:53:51 GMT
Mo is now safely in the hands of Chris - whose garage floor no longer looks neat and tidy!
I did take some photos but they were thought too horrific for those of you on here of a nervous disposition Chris will produce some later showing the finished results of his remarkable skills,
Thanks Chris
Post by Penguin45 on Aug 17, 2016 20:51:00 GMT
Errr. Got the front n/s floor, chassis leg and bulkhead finished. Front of sill, membrane and wheel arch will get started on tomorrow. Chris.
Post by snoopy11 on Aug 17, 2016 21:25:15 GMT
Yep.. That's made a mess on the garage floor.
Looks like the rust worm got a good hold there.
UMO 406G
Aug 18, 2016 6:04:04 GMT
Post by peppib on Aug 18, 2016 6:04:04 GMT
Shame the MOT man didn't spot it back in March!
At least the expert repairs are looking good
This middle age lark is no good - I am knackered this morning after my trip. I used to be able to make Durham to Exeter and back in a day, and suffer watching Exeter City lose as they always did when I was there
Tempus fugit or something like that
Post by Penguin45 on Aug 18, 2016 17:38:50 GMT
Closing panels in n/s whell arch. Chris.
