Post by charlypm on Feb 7, 2016 18:20:59 GMT
While cleaning my transmission in my parts washer I flipped over and later found a part in the part washer. I'm not sure it even came out of it, there were some other parts in a bowl that fell over. Did this piece come out of the tranny? Found it, locating plate for the shift rods. Attachments:
tran part.pdf (120.42 KB)
Post by Penguin45 on Feb 7, 2016 19:55:21 GMT
I'm afraid the link is broken, Charly.
Post by charlypm on Feb 13, 2016 2:35:38 GMT
Not a transmission question, but a oil pump question. Are the internal parts of the Landcrab oil pump the same as the MGB oil pump and can be swapped? The external sure is different.
Post by Penguin45 on Feb 13, 2016 18:32:24 GMT
Not sure - unable to directly compare part numbers. The shaft and rotor were replaced by 12H 2225 (oil pump) as an assembly.
Post by foglaursen on Feb 14, 2016 7:56:45 GMT
It is the same. I have one on my Morris 1800 MkI Peter
Post by dave1800 on Feb 14, 2016 10:13:37 GMT
I believe the oil pump on Mk1 cars (all or early?) may be different to later vehicles and that is the reason you cannot change the camshaft in-situ (with Tommy's inner wing mod) on early cars. Whether the inners are the same I have no idea. Sorry not very helpful.
