Post by andrewa on Apr 22, 2015 8:17:14 GMT
Does anyone know what difference is between the ten gallon tank fitted to the 1800 and the twelve gallon tank fitted to the 2200? Before anyone says it - I know it's two gallons! Is it just deeper from the bit where it bolts on, downwards and if so, by how much? I've got a ten gallon tank I want to turn into a twelve gallon one so dimensions for the twelve gallon would useful if anyone knows? Cheers Andrew
Post by tripplescrew on Apr 23, 2015 17:28:46 GMT
The only difference is the depth of the tank everything else the same.
