Post by Penguin45 on Apr 7, 2015 14:53:22 GMT
At Dave1800's suggestion, I kept a log of expenditure relating to getting the Red Dog back to roadworthy condition. I think it covers just about everything. Bear in mind that this was a pretty extreme case - hopefully anyone else planning the job will find the total is lower.
I've broken it down into sections, which makes it easier seeing where the money went.
SERVICES.
Trailer hire: £50
Fuel to collect car : £69
Lunch for two(!): £9
Tyre fitting: £40
MoT test: £54
Total: £222
BODYWORK RESTORATION.
CO2 gas (disposable): £26
Large Hobby Gas 5 bottles x 2: £60 (Exchange)
Rear wheel arch repair sections: £55
Mini rear panel: £12
Large tin of Hammerite: £22.50
Sheet 0.9mm steel: £15
Primer/etch primer: £15.75
Flap wheels x 10: £10 (Bargain!)
Huge tub of filler, spreaders, coarse sandpaper: £32
Sandpaper, primer x 2: £20
Chassis paint: £10
Sundry abrasives: £27
5kg 0.6mm welding wire: £18
3mm steel plate: £26
Damask Red aerosols x 3: £34
Bonnet: £25
Total: £408.25
MECHANICAL RESTORATION.
Battery: £46
Set of 4 brake hoses: £24
½"UNF x 5" bolts x 2: £15
Stainless steel caliper pistons x 4: £50
Sundry brake fittings: £12.50
Kunifer brake pipe: £15
Heater hose and clips x 6: £7.47
Hyro suspension hoses x 2: £90
Hydrolastic fluid 4l: £19
Starter solenoid: £9
Front exhaust pipe: £30
Water pump: £26
Front displacer: £40
Barum Brillantis tyres x 4: £134
Thermostat and gasket: £4.41
Window winders x 2: £7
Total: £529.38
ITEMS USED FROM OWN STOCKHOLDINGS.
Sills x 2
Rear brake cylinders x 2
Various lamps
Tail light assembly
Front brake seal kit x 2
Master cylinder seal kit
G valve seal kit
Girling servo seal kit
Big engine mount
Wiper blades
Rear brake shoe set
Front brake pad set
Enough bits to make a headlight (!)
Electrical connectors - lots.
Approx value: £350?
ITEMS DONATED.
1970 Austin 1800 MkII
Bonnet (sadly not usable)
Austin grill
Front wheel arch liners
Carpet set
Set of seats for refurbishment
Several different interior clocks
I have no real idea of the value of these as a whole, but my thanks go to all who passed things on to me.
Total actual expenditure: £1159.63
Including parts from stock: £1509.63
TIME.
It took 513 days to get it back on the road, that's 73 weeks and 2 days. Knock off 7 weeks due to unforeseen illness - 64 weeks and 2 days. I reckon that I averaged 2 hours 3 evenings a week, 4 hours on a Saturday and 6 hours on a Sunday, which adds up to:
1024 hours (!)
A restoration business will typically charge £25/hr, so £25,600 perhaps!
Obviously some of the work may have been done differently or faster by professionals, but even allowing for that, this car was never going to be viable as a commercial restoration.
So there you go. Obviously each restoration is different. Looking at the figures above, it's worth noting that the time went into the bodywork and the money went into the mechanics.
I will try and finish this off with the painting process when that gets done.
For now, I'm going to enjoy her for a bit.
SERVICES.
Trailer hire: £50
Tyre fitting: £40
MoT test: £54
Total: £222
Chassis paint: £10
Bonnet: £25
Total: £408.25
Battery: £46
Water pump: £26
Total: £529.38
Sills x 2
Various lamps
Tail light assembly
G valve seal kit
Big engine mount
Wiper blades
Rear brake shoe set
Front brake pad set
Approx value: £350?
ITEMS DONATED.
Austin grill
Carpet set
TIME.
1024 hours (!)
