this mounting can be replaced with Toyota fj 60 lancruiser engine mounting number 12861-61020
this mounting is about $102 for the genuine Toyota part, but it available from Germany, china, & Australia at various prices, e.g. from
www.4x4world.com.au at about $16.00 each plus postage, cheap as chips.
I have fitted these to four cars so far with no problems, but!.
I must warn you that damage done by having broken sandwich mountings for any length of time can cause the two front mounts to move towards the radiator & take on a permanent status.
this means that when you fit the replacements you will be trying to pull the engine back towards the battery end .
you must make sure your front mountings are square to the body or your old front mounts will be pulling the new ones in a direction they do not want to go.
just google mounting 12861-61020 to see part and price, I suggest 4x4 world as above or mackay silent rubber Bentley Victoria, your local motor factor, I. e. veale engine parts can do it all for you if you like.
I have patterns for the positioning of this arrangement, but I do not want to have to send a pattern to each and every one of you.
this is something that has to be thought about, perhaps one set of patterns in circuit, what are your thoughts.
there is a small amount of trimming to do for one of the mounts.
all the best.
cptkennykidna
