Post by Penguin45 on Feb 17, 2018 21:08:44 GMT
So for all four of you no doubt bursting with anticipation, here's what happened. Ron fitted a plate to a rocker pedestal to hold a dial gauge, set no. 1 valve to timing clearance and brought the engine to TDC. I was dispatched under the car to observe where the timing mark on the pulley was positioned. We have the four tangs underneath going from 0 - 20° BTDC. The timing mark was approximately 20° after TDC. Ron was correct in his diagnosis. We stripped down the radiator end of the engine bay, removed the pulleys and chain case to find: VOF707J by Penguin 45, on Flickr The chain wheel dots could not be made to align. You're looking in a cunningly positioned mirror, BTW. VOF707J by Penguin 45, on Flickr A short time later, new chain and the dots are aligned. What can possibly go wrong? New tensioner for a start. Badly drilled holes don't line up, so that's going back to Moss. The old one was deemed to be barely worn, so it went back on. VOF707J by Penguin 45, on Flickr We re-built the engine bay and set about the top of the engine itself. Head was re-torqued, rocker gaps set to .015" before the compression tester came out. This showed 150-155psi across the cylinders. The vacuum gauge was connected and the engine run. Despite extensive tinkering with timing and carb settings, the gauge hovered between the 10 + 11 marks. Ron not a happy bunny at all.... To be fair, we were both knackered by that point, so I have brought the car home. Opening the rocker gap is an option to be tried again, although it has been noted that .018" is the max specified on competition engines. The car is pinking in every gear under acceleration, so I will re-set the timing to book settings tomorrow and see what happens. It's got plenty of low rev pick-up, feels flat in the mid range and won't accelerate on any sort of worthwhile hill. There you have it. One step forward, one step back. Chris.
Post by tommydp on Feb 17, 2018 21:50:58 GMT
Chris, I was actually waiting for a post, as I was so excited! Well, I can say this brings me back Better leave it and get back to it. If you set number one intake valve to 0.020 the pushrod should just start to lift/ not be able to rotate at 5 degrees btdc. Where you of the impression that someone have been into the timing gears, or did it look original? Hard to tell from the pics, what happens to the marks with the tensioner activated? I prefer setting the crank and cam in the correct place with the cog wheels only first, using a metal rule to mak a straight line through centre of marks, and middle of crank and cam. Then I put the chain on on the bench and check with the ruler as I pull the wheels apart with chain on. I suppose you measured while the tensioner was in place and operating? Did you establish the true tdc with a piston stop and was the timing disk used? Well, hang in there Chris! You'll get there! Regards, Tommy
Post by dave1800 on Feb 18, 2018 1:48:11 GMT
Don't panic! It can all be resolved by applying logic and one thing at a time and in this order. My suggestion which concurs with the Moss videos linked below can be summarised as: 1.Check the TDC pointer and crankshaft pulley marker are correct by observing the piston movement (Moss video 2). Re-mark if necessary. 2. Check the camshaft timing specs , eg 5,45,40,10 using the timing disc 3. Set the camshaft timing (Moss video 3), determine the camshaft profile 4. Reset the valve clearances in light of the camshaft fitted ie probably 0.015" or 0.018” 5. Set the ignition timing to w/s manual spec 6. Tune the carb 7. Re-measure the vacuum and compression. 8. Have a beer The first thing to do is to sort out the timing marks. There are some very clear Youtube videos posted by Moss that are well worth watching (especially the 2nd and 3rd which show you what to do). Moss 1Moss 2Moss 3Observations There is clearly something fundamentally wrong. You noted that when the engine was set to TDC that the crankshaft pulley timing mark was around 20 degrees after TDC. My question is how was TDC determined? If using the dial gauge and using No1 valve opening as the indicator this would not be accurate as it would include any errors in the valve train. You would also need to make an assumption about the camshaft profile. I would suggest if you have not already checked TDC by a method similar to Moss that this is your priority as all other settings stem from this. The photo showing the old timing chain does show some misalignment. While it is difficult to determine from the angle you had to shoot the photo it looks to be less than one tooth which is 18 crankshaft degrees, but again without the tensioner I cannot be certain. Errors can occur if the rubber between the inner and outer sections of the crankshaft pulley distorts making the timing mark wrong but 20 degrees seems excessive unless there are very obvious signs. The later crab pulleys had a revised mark when the pointers were moved to the top of the timing cover but the difference was of course far greater than the 20 degrees so that can be discounted. There were two or three different tensioners for MGBs, the problem could be Moss’ fault or you may have a different back plate. A Tommy says when it comes to setting the camshaft timing you need to open the tappets to 0.020". Of course you may not be 100% certain what camshaft is fitted to your engine so the first task is to take readings. The standard Mk11 cam was 5,45,40,10 and the MGB / 1800S, 16,56,51,21. As you know a steady low manifold vacuum can result from an air leak, retarded ignition timing or late valve timing. Given your compression reading is even and now more reasonable other factors can be reasonably discounted. As a matter of interest where have you taken the feed for the vacuum gauge? However, you noted pinking in every gear under load which would occur if the ignition timing was over advanced. This questions in my mind whether the initial observation about the crankshaft pulley marking being off by 20 degrees is in fact correct? The fact that you experienced good low down power could also indicate an over advanced ignition timing – but conflicts with the vacuum gauge. Has the vacuum gauge been checked against a known good engine? Remember the vacuum gauge helpDavid
Post by Penguin45 on Feb 19, 2018 0:34:18 GMT
Thank you both for your comments; very comprehensive and well explained. You might make a mechanic out of me yet. I have done some very basic stuff today. One was to pull the dizzy and clean and lube everything, set the points up again and find out that the new (expensive( vacuum capsule wasn't working. I have refitted the previous one. This is of unknown provenance as the markings are unreadable. From a simpletons point of view, most 25D dizzies on 'Crabs seem to sit with the vac tube somewhere around the 1 o'clock mark. Setting it by the book put the dizzie over at about 45° and pinking like mad. Several trips out saw the dizzy retarded and retarded until the pinking stopped. Surprisingly enough the vac capsule was now pointing at around the 1 o'clock mark. Ady came down for a while and we finessed it a bit with the carb and the timing, but no major improvements have been observed. The car now starts easily instead of bouncing against compression and the running on issue has more or less disappeared. Not a very scientific approach I realise, but the car is rather more usable at present. Idle is slightly lumpy, but she pulls well through the gears and the revs without pinging every time I put my foot down. I will pick up a vac gauge during the week and see where we are. Chris.
Post by dave1800 on Feb 19, 2018 3:42:28 GMT
It is highly unlikely that many of the vacuum advance mechanisms are still within spec as the diaphragms and springs age.
You can set up a test rig fairly simply by attaching the mechanism to a hypodermic syringe and T-ing in a vacuum gauge and checking the advance with a timing light. (Plug the carb take off to avoid an air leak). You can then see if the unit you have is operating reasonably close to the original. As your cylinder head has been skimmed in theory raising the compression it possibly needs slightly less vacuum advance.
The vacuum advance mechanism used on Mk11 distributor 41234 shows 5 degrees advance starting at 1" Hg and ending at 12 degrees at 7" Hg (crankshaft degrees and fairly linear between these two points.
The most important factors from the engine safety perspective is that the advance returns smoothly and quickly to zero under wide open throttle and anywhere from around half open throttle or slightly less without sticking. Driving without the vacuum advance operating will cause hesitation off idle, poor drivability under light loads and higher fuel consumption but won't damage the engine. Over advancing ignition timing is the killer. If the vacuum advance diaphragm is punctured it will not perform properly and be a source of an air leak affecting the mixture. Remember the crabs used ported vacuum take offs so there won't be any vacuum advance at idle.
Post by Penguin45 on Mar 4, 2018 18:35:42 GMT
As you will have realised, nothing has been happening over the last couple of weeks due to the extremely adverse weather conditions. I did manage to replace all the rear rubber petrol pipework.
Today I went out to the garage to fetch the oil and brake fluid prior to a quick check of the levels and found the place awash due to a burst pipe. This turned out to be a popped compression joint, so was fairly easily sorted, although getting soaked to the skin in -2c wasn't exactly how I planned to spend my afternoon. Got changed and spent a happy hour sweeping water out of the garage. Hopefully nothing is terminally ruined.
Oh, then I checked the levels in the car.
Post by Penguin45 on Mar 5, 2018 12:25:50 GMT
However, I should have tried starting her yesterday. Would she go this mornng? Would she 'eck as like. No spark. Proved to be the condenser, as when replaced she fired up straight away.
Further to comments concerning the vacuum advance, I have managed to source a refurbished 41415. This is a 45D, rather than a 41234 25D, but the two interchange. Hopefully it will sort out some of these problems.
Post by dave1800 on Mar 6, 2018 1:31:14 GMT
Hope you've recovered from your ice-cold shower and the 45D distributor sorts out the issues! The rate of capacitor failure is just astounding - the Peter Burgess solution is to use "proper" electronic high quality components as we've discussed before but they won't currently fit inside the distributors as far as I know.
Post by Penguin45 on Mar 8, 2018 18:24:13 GMT
So much repro Lucas stuff is just junk these days.
The starting problem didn't entirely go away. The car was driven for five hours on Wednesday, so you would think that it would be brimming with electrical goodness. Engine chugged over slowly this morning. A quick check showed 11.54vDC. Dropped the spare battery in and "Whizz!" - away she went first turn of the key.
Post by dave1800 on Mar 9, 2018 2:10:29 GMT
Just when you needed 11.55V - glad it wasn't showing AC David So much repro Lucas stuff is just junk these days. The starting problem didn't entirely go away. The car was driven for five hours on Wednesday, so you would think that it would be brimming with electrical goodness. Engine chugged over slowly this morning. A quick check showed 11.54vDC. Dropped the spare battery in and "Whizz!" - away she went first turn of the key. Chris.
Post by Penguin45 on Mar 26, 2018 23:14:35 GMT
Things are plodding along. The car is running quite nicely. I did acquire a factory refurbished 45D 41415 distributor, which was fitted two weeks back. Ron sort of sniffed at it, took it to pieces, cleaned and oiled everything and fitted the genuine (red) Lucas points and condenser and a Distributor Doctor red rotor arm which I had aquired separately. When fitted, we tinkered with the timing a bit and the result is better. Much better. Starts first time, doesn't run on as much and the fuel consumption has improved. The car is running very nicely. However, the vacuum gauge is still only showing 12. Austin 1800 by Penguin 45, on Flickr Tweaking in progress. Ron approves. Austin 1800 by Penguin 45, on Flickr And a few days later. Not sure what to do about this. I could obsess about the low vacuum reading, but the car is running nicely with adequate power, so leaving things alone is a tempting option. However, I have assembled a kit of Mobelec parts over the past three months which would allow the car to run a positive earth electronic ignition system, which interests me greatly as it's all period stuff. Reading the WM shows that 150psi compression is about right for an LC engine, and that lower vacuum gauge readings should be expected. That's fine, but the car has flat top pistons and the head has had a .009" skim, so should be a high(er) compression engine. Bah, humbug. The MoT is due in a few weeks, so there are other things to deal with. Chris.
Post by dave1800 on Mar 27, 2018 2:27:23 GMT
You should have taken the photo at 77 mph - oh sorry that's not allowed!
I'm sure you are aware that there were a range of combustion chamber volumes which from memory are from around 39cc "S" to 43.5cc as well as flat top and domed pistons so without dismantling and taking measurements there's no way I can think of to determine the actual CR. The vacuum gauge reading is very low even for a LC engine. The quickest way to check if there's an air leak as I mentioned to Paddy is to raise the idle rpm to around 1500-2000 using the throttle screw; this negates the effect of a leak to a great extent and is a technique used on modern diagnostics to check reasons for short term fuel trim figures.
Is the Mobelec unit the capacitor discharge version? I had one on my MK1 carb that was hit by a Landrover and it destroyed the pickup sensor and the rest of the distributor as well!
Post by Penguin45 on Apr 19, 2018 22:42:04 GMT
A little reminder that it's always worth putting information up in forums, as sometimes it is picked up on. Mark, the PO of the car, has been in touch to say that the camshaft was changed when the engine was rebuilt some years ago. Now we've got something to go on.
Post by dave1800 on Apr 20, 2018 0:30:11 GMT
So, which cam is it? Sounds as though you may need to print a cam timing wheel sticker?
Post by tommydp on Apr 20, 2018 6:26:40 GMT
Oh, cam timing.. this brings me back... not nice memories:-)
