Post by tommydp on Mar 5, 2013 19:07:36 GMT
Hi all! I'm fitting the modified large mounting to my white one, as we speak. Question is: do I fit the original bracket, which goes between the block and original mounting, with the modified assembly? Regards, Tommy
Post by Penguin45 on Mar 5, 2013 20:00:21 GMT
Metal strip with two holes? It's just a spacer - I left it off.
Post by tommydp on Mar 5, 2013 20:47:07 GMT
More a bracket I'd say, quite thick and has a hole in front for steady bar as mounted on the S. I called Tony, who confirmed it should not be mounted with the new assembly. The modified one has a hole for the steady bar. Marvellous guy, Tony:-)
Post by Penguin45 on Mar 6, 2013 0:54:08 GMT
Tony is extremely knowledgeable - one of the good guys.
Put up a picture and let's see if we're talking about the same thing.
