Post by indianajones on Mar 3, 2013 19:58:13 GMT
Hey there lads, got a workmate with a Maxi who's trying to remove the gear selector rods so he can get the exhaust manifold off.
The Haynes book of lies tells him to remove some pins with a nail punch, but it seems the otherside is blocked and there isn't enough room for the pins to come out (if that makes sense).
Any ideas?
Post by dave1800 on Mar 4, 2013 5:46:19 GMT
I assume he has moved the gear stick to rotate the rod? Never looked at a Maxi so just guessing
[quote author=indianajones board=tech thread=438 post=3525 time=1362340693]Hey there lads, got a workmate with a Maxi who's trying to remove the gear selector rods so he can get the exhaust manifold off.
Any ideas?
-Andrew[/quote]
Post by Penguin45 on Mar 4, 2013 12:25:35 GMT
It's the same set up as the rod change 'Crab, Indy.
Punch and hammer - drive out the roll pin. Replace with new one - they're only pence. Top rod bolts through a rubber bush and that can be a real s@d to get off.
Post by indianajones on Mar 4, 2013 18:51:48 GMT
Cheers guys, I'll let him know.
