Post by indianajones on Jul 26, 2012 21:11:20 GMT
Hey guys, should get the crab back tomorrow and I know a few of the trim rivets (i.e. the ones that hold on the front wiskers and cow hip chrome etc) had been removed when some rust was removed.
What would be a good solution to replace them?
Post by Penguin45 on Jul 27, 2012 0:15:05 GMT
Stainless steel M3 bolts. Grind the head to a "T" section which will slide up the inside of the trim strip. Open holes in front panel to 3.2mm and fit. Simples.......... Chris.
Post by indianajones on Jul 27, 2012 0:30:32 GMT
Awesome Do you use any sort of sealent/rubber washer etc to stop water getting in? (More so for the cow hips) -Andrew
Post by dave1800 on Jul 27, 2012 8:26:43 GMT
Try going to your friendly local car body shop to see what they have around, preferably made of strong nylon type plastic to avoid corrosion. Regards David Hey guys, should get the crab back tomorrow and I know a few of the trim rivets (i.e. the ones that hold on the front wiskers and cow hip chrome etc) had been removed when some rust was removed. What would be a good solution to replace them? Cheers, Andrew
