Post by tommydp on Oct 12, 2011 21:06:25 GMT
Hi all!
Been working on a 2200 Princess this evening. It belongs to an older gentleman, who has owned it since it was 2 years old. As mentioned in an earlier post the car has been misfiring and stalling while driving, and last time I suspected fuel starvation at one of the carbs, the one to the right when wieving the engine from front, as the three corresponding cylinders were not firing though they had a spark.
Well, we removed the carbs, they had never been opened according to him.. You would not believe the contents of those float chambers.. No doubt the float valve could have been sticking etc. It's a wonder the car has run at all:-)
So I removed the floats and float needles and cleaned everything up, blowing compressed air through etc. The circular float sealing rings seemed fine, so put them back in. I marked the position of the float lids and did not mix any parts between the two carbs.
The car ran beautifully, but I soon discovered petrol leaking from both carbs, one worse than the other. This comes from between the float lid an carb body, so I suppose the sealing rings are not doing their job.
Any ideas or experiences with this? What can be done to get this tight? I will order new seals tomorrow anyway, as I can't see anything else causing this.
Regards, Tommy:-)
Post by threelitre on Oct 12, 2011 21:28:42 GMT
You can try plumber's teflon tape as a temporary solution...
I've had this too - ring looked fine, but it was leaking badly.
Post by Penguin45 on Oct 13, 2011 0:21:24 GMT
Bottom cover on one of my carbs warped on my old Princess 2.2 (25 years ago...). We flatted it, and the base of the carburettor, on some fine wet and dry paper (wet, so that it stuck to a sheet of glass) and with a new seal was fine.
I suspect that that was more luck than judgement!
Post by tommydp on Oct 13, 2011 13:31:09 GMT
It did seem as both lids were warped, however they did not leak prior to this work..
I have ordered new seals now, and we'll see. Perhaps I'll add some petrol resistant sealer when putting it together again.
I would really like a 2200 in the crab, ah, the sound of that engine..
Post by ahctog1 on Oct 13, 2011 19:42:11 GMT
On the HS6 there is a breather directly under the inlet pipe with a cover on each float chamber, if the needle valve is not shutting completely, fuel will leak from this breather. Foxed me for a while. Hope this may help
