Post by Keef on Dec 12, 2010 17:26:42 GMT
Post by Penguin45 on Dec 12, 2010 18:55:21 GMT
I'll take the forum set-up every time - much easier to follow that the notice board type.
Chris, P45.
Post by Keef on Dec 12, 2010 19:13:55 GMT
I'll take the forum set-up every time - much easier to follow that the notice board type. I agree, but I think the Google Group has it's place.
Post by Admin on Dec 12, 2010 21:42:20 GMT
I'll take the forum set-up every time - much easier to follow that the notice board type. Chris, P45. This is pretty much the reason. I just thought it would be be better to have one central "proper" forum, as the Google Groups seem a bit difficult to follow, and a bit on the quiet side. I thought people might be persuaded to contribute more to a traditional forum?
Post by Penguin45 on Dec 13, 2010 1:30:35 GMT
Groups don't tend to pop up on Google if you're searching (In my experience, at least.) - forums do seem to be easier to find.
Chris, P45.
Post by Keef on Dec 13, 2010 5:47:02 GMT
Groups don't tend to pop up on Google if you're searching (In my experience, at least.) - forums do seem to be easier to find. Interesting point. I assume Groups are blocked from search engines, which is odd. Edit: Just put "landcrab forum" into Google and came up with this interesting question! www.aronline.co.uk/forum/viewtopic.php?f=27&t=16676
Post by ahctog1 on Dec 18, 2010 0:42:38 GMT
I would guess the answer to his question is to not use a gearbox that was built for a later (and apparently different) model! I must admit to having wondered if the 2200 engine and box from a wedge would fit, but assumed after reading that they were prone to drive shaft problems on the wedge, that there was a difference. The old adage of sticking with the original may prove good again!
Getting back to the point of forum over group thing, for me, forum every time.
Post by Penguin45 on Dec 18, 2010 0:50:07 GMT
That's our Tommy, isn't it? My car has a MkIII engine and gearbox and I "think" automatic drive shafts - it seems to work very well.
Post by Keef on Dec 18, 2010 3:40:19 GMT
I would guess the answer to his question is to not use a gearbox that was built for a later (and apparently different) model! Some folk may not have a choice. THe chap from Australia who purchased a Six without an engine for example. It's nice to see these things can be done, if needed, although better to use original, as you say, if possible. Doesn't Edwin have a later engine fitted? :b As to the forum v group question; it looks promising as we have gone from 12 to 18 Members in the last week. Nothing to stop folk being on both. At least one has said they prefer the group layout.
Post by ahctog1 on Dec 18, 2010 9:12:01 GMT
I would guess the answer to his question is to not use a gearbox that was built for a later (and apparently different) model! Doesn't Edwin have a later engine fitted? :b Other way round, his engine appears to be an early one from the number, they must have swapped things like the distributor over,'cos that is the later type. Odd that, they left the steering pump on for no reason. If anyone needs a six pump, I still have it.... not sure if it works though.
Post by deconstruction on Sept 6, 2015 7:28:07 GMT
I recall (from my time at a BL-dealership in the '70s) that there were problems with the CV-joints at the inner/gearbox end of the driveshafts on the early manual six-cylinder 18/22 series cars. The six-cylinder automatics and all four-cylinder cars did not have these problems. The factory resolved this by (retro-)fitting redesigned engine mountings which slightly changed the position of the engine.
