Post by cheesyblob on Jun 4, 2011 7:15:02 GMT
Sorry if this is a stupid question, but does anyone one know the carb sizes for the Maxi, the Landcrab, and the 3-Litre? Also, how many carburettors does the 3-Litre have?
Post by Penguin45 on Jun 4, 2011 21:22:15 GMT
Hi CB,
Maxi - 1 or 2 SU HS6 carbs, depending on spec. 1800 - 1 SU HS6 1800S - 2 SU HS6 P45's 1800 - 2 SU HIF4 ;D 2200 - 2 SU HS6 or 2 SU HIF6 3 Litre - 2 SU HS6
These will be jetted and needled in many different combinations to give the exact performance required.
There aren't many stupid questions - if you don't ask, you may never get an answer.
P45.
Post by cheesyblob on Jun 5, 2011 6:44:05 GMT
Hi CB, Maxi - 1 or 2 SU HS6 carbs, depending on spec. 1800 - 1 SU HS6 1800S - 2 SU HS6 P45's 1800 - 2 SU HIF4 ;D 2200 - 2 SU HS6 or 2 SU HIF6 3 Litre - 2 SU HS6 These will be jetted and needled in many different combinations to give the exact performance required. There aren't many stupid questions - if you don't ask, you may never get an answer. P45. Ok thanks
