Post by kalaika on Oct 7, 2024 12:09:12 GMT
Hi all, is there an easy way to remove the radiator from an Austin 1800 MK2, is it always necessary to remove the fan? Many thanks
Post by Penguin45 on Oct 7, 2024 18:34:21 GMT
Eyup K.
I don't think I've ever removed the fan.
1/ Remove hoses. 2/ Release stabiliser bracket from thermostat housing. 3/ Remove rubber strip (If still present). 4/ Release retaining screws (front and rear) from top radiator cowl and lift away. 5/ Undo the two bolts at the bottom of the radiator.
You should then be able to wiggle the bare radiator out.
Post by kalaika on Oct 7, 2024 22:30:30 GMT
Thanks Chris,
Will take my time this time around and see how i go.
regards Craig
Post by dave1800 on Oct 9, 2024 8:21:44 GMT
Chris, you're braver than me. I always opted for removing the fan blades first taking care not to scrape the back of my hands. I did however take out the lump with the radiator (and fan) in place but removed them for reinstalation. David Eyup K. I don't think I've ever removed the fan. 1/ Remove hoses. 2/ Release stabiliser bracket from thermostat housing. 3/ Remove rubber strip (If still present). 4/ Release retaining screws (front and rear) from top radiator cowl and lift away. 5/ Undo the two bolts at the bottom of the radiator. You should then be able to wiggle the bare radiator out. Chris.
