Post by jeff on Jul 21, 2024 18:41:02 GMT
Hi y'all.
The progressive accelerator cable linkage on the single carb Mk1 appears unique and probably isn't made by SU. Does anybody know where I could get the tiny nylon bushes from,that fit on the connecting rod? Tony Wood is also looking into it.
Thanks
Jeff
Post by Penguin45 on Jul 22, 2024 9:08:13 GMT
Not much info out there, Jeff. Carburettor Linkage by Penguin 45, on Flickr SOMERFORD MINI have AUD2884 listed, otherwise it looks like it was supplied as an assembly. I think I've got a spare carb in the garage; I'll go and have a look later. C.
Post by Penguin45 on Jul 22, 2024 14:44:04 GMT
Post by jeff on Jul 22, 2024 15:05:52 GMT
Well bugger me Chris! Err, on second thoughts, best notš¤£ That's fantastic, you're a star. Thank you. I'll pm.you.
Jeff
Post by jeff on Jul 23, 2024 12:23:55 GMT
Chris manufactured the Throttle link bush parts for me out of brass, they came today and are a perfect fit. Dead easy to fit apart from the old starlock washer that holds it all together that was split and I don't have a spare so I did a temporary improvisation until get some washers. Also a good opportunity to give a tiny drop of oil on all the carburettor links and cam.
It's a great fix and the accelerator pedal now has a much nicer feel. Well done Chris and thanks.
Post by andrewa on Jul 25, 2024 9:45:47 GMT
Looks great - excellent!
Post by Penguin45 on Jul 27, 2024 13:57:05 GMT
Cheers chaps. Tony wants them, so I've done some making. Carburettor linkage bush by Penguin 45, on Flickr Starlock washers haven't turned up yet; when they do I can send them off to the Emporium. C.
Post by jeff on Jul 27, 2024 14:38:52 GMT
Excellent stuff Chris.
