Post by jeff on Oct 19, 2023 15:40:24 GMT
Hello all. I'm sure I read that (Chris perhaps??) Had a small number of G valve rebuild kits, seals etc for sale. It was in a post from around 2014 I think.
I've decided to have a go at overhauling My 1966 MK1 G valve now I can't find anything obviously wrong with the servo causing the brakes to hang. By the way, the brake lights stay on when this happens, so pressure is remaining within the G Valve, where the switch is fitted.
Please give me a prod if you have a kit which I can buy.
Thanks Jeff
Post by dave1800 on Oct 20, 2023 0:51:18 GMT
Hi Jeff
I appreciate it's pointing out the obvious but have you already checked the flexible brake hoses in case one of them has deteriorated internally and acting as a partial check valve?
Post by Penguin45 on Oct 20, 2023 8:40:07 GMT
I do have some G valve kits. I'm down in that there London Town at the moment, so I'll drop you a message when we get back on Monday.
Post by jeff on Oct 20, 2023 10:58:53 GMT
Thanks Chris, much appreciated.
DAVE, Thanks for the tip (not always obvious). However, I do feel that if it was flexible hoses causing the problem, then yes, they'd cause the affected brake(s) to hold on by maintaining pressure, post blockage towards the wheel cylinder.
In this case, the brake lights stay on. I know this because I have a tell-tale warning lamp fitted in the dash, wired into the brake light circuit. That, I think indicates pressure is being held in the servo or the G valve where the brake light switch is fitted and so is before any flexible hoses (if you see what I mean).
I know it's not the master cylinder because I put a new one in, which didn't make any difference. So, that leaves the pipework between master cylinder and servo, and pipework between servo and G Valve. I know this to be good because I replaced it all last year, made with a proper bender etc, and the problem existed before I replaced it.
Finally, that leaves only two possibilities which could maintain pressure enough to keep the brakes and brake lights on. They are the servo itself, and the G valve.
I've just replaced the air valve on the servo and tested it. The car sits in the garage with the front wheels about 4 inches off the ground, slightly nose up on hydraulic ramps. I can operate the brakes 100 times, very fast and hard. There is a definite "thud" and rush of air heard from the servo each time, and the tell-tail brake light ALWAYS goes off immediately the pedal is released. It only stays on, and you can feel the drag, when the car is out on the move or just stopped. The brakes release fully and the tell-tale goes off, after a few seconds or when moving off again. The latter would be a very similar symptom to collapsed flexible hoses, like you say.
No matter what I do, or how often I stamp on the brakes while stationary, I cannot induce the fault. I.E, make the tell-tale and brake lights stay on.
I did notice the hang, and the tell-tale remaining on when facing downhill, shunting around on my driveway which has quite a steep gradient. No hang is noticed when facing backwards on the steep drive.
So, in conclusion the next step must be to eliminate the possibility of a sticky G Valve. I hope this all makes sense.
I did find a new old stock G valve for sale on a parts website for £109..ouch! But even that would have old seals and lubricant so it's probably gummed up inside by now, so I'll see what Chris comes up with and take it from there.
Jeff.
Post by dave1800 on Oct 20, 2023 23:11:45 GMT
Hi Jeff
Your analysis does seem to be pointing to a problem with the G valve; I think I have mentioned previously that the ball can stick when bleeding the brakes and the w/s manual suggests a way to release it. Many years ago I had an intermittent problem with a Mk11 valve that resulted in the rear brakes locking up which was quite entertaining. That valve was slightly simpler than the one used on Mk1 cars. I found the problem was mitigated by slackening off the rear brake shoe adjusters but replacing the valve sorted it out.
Post by jeff on Oct 21, 2023 15:15:18 GMT
Well well well, I was able to get out in the dry today and do several tests uphill, downhill, forwards and backwards.
The deeper I got into these tests the more interesting it became. I now find that the "hanging brakes" happen under light braking mostly, both backwards and forwards, and on the level if I release the brake slowly. I know all brakes are hanging because on a steep slope, I can clearly hear the fronts let go a second or two after releasing the pedal.
Now this is where it gets interesting. I switched off the engine and pumped the brake until all the vacuum was exhausted from the servo. Then,I turned on just the ignition and let the car roll downhill. Under hard and light braking, the brakes released immediately I took my foot off the pedal.The brake light tell-tale lamp going off and the car rolling forwards. With the engine running, I could get the brakes to hang but only if I let my foot off slowly from light braking.
In conclusion (again), I think the servo air valve hydraulic piston needs removing and inspecting. Of course it could be a combination of servo and G Valve giving problems but I think the servo is the starting point.
I have read on another site, Lotus I think,that this problem is known to Lockheed, and they, apparently, recommend removing one of two seals from the little air valve hydraulic piston to reduce its resistance. They say its quite safe (allegedly).
So that's the next step. I will of course update in due course.
Jeff
Post by dave1800 on Oct 22, 2023 8:23:02 GMT
Hi Jeff If you find problems with the G valve when you replace the seals (and ball?), this company has NOS available for £10. It appears it is a Land Rover part and no guarantee of its internal condition of course, but at the price .... I suspect (but don't know) if the same valve was used on different vehicles and possibly the only difference was the angle they were mounted and the internal spring although the bores may differ of course. (Early MK1 cars had the G valve mounted at a different angle to later Mk1 cars and the valve used on Mk11 cars was mounted at at yet another angle. Worth keeping in mind maybe? G valve hereDavid
Post by jeff on Oct 22, 2023 15:08:11 GMT
DAVE, Thanks for the link and info Unfortunately, the part number shown on the G valve doesn't match with what I found in an online old Girling parts catalogue for our earlier cars. The number appears too high so it's possibly for a Land-rover I will check further.
To make matters worse, I stripped and cleaned the servo air valve today, including its little piston, illustrated in the photos in Chris's Post. Cleaned and greased with Girling brake seal grease, new rubber diaphragm, slightly streching its valve spring, and a good bleed.
Road testing revealed this:
Brakes only dragging/hanging under light braking when going forwards, brake lights remaining on for a few seconds.
Rolling back on a steep hill and braking no drag.
Moderate and emergency braking, no drag.
As far as I'm aware the servo has a push through facility to bypass its action under light braking and this is when the problem occurs.
I can't see what else could be holding all four brakes unless something has collapsed or swollen in the G valve.
I'll wait until Chris sends me a repair kit and tackle the G valve. I'm sending myself in ever decreasing circles with this one slowly disappearing up my own preverbial orifice. My head tells me it's the Servo but the testing shows its the G valve but I would have thought the G valve would play up under heavy braking and only affect rear wheels, not all four.
To make matters worse, the fault is intermittent to some degree.
AAAHHHGGGGG.GRRRRRRR
JEFF.
Post by Penguin45 on Oct 22, 2023 17:53:39 GMT
I've got to say, Jeff, that the G valve is such an incredibly simple device that, unless it really has fully furred up, I don't see how it can fail!
I'll try and get you a kit away in the post tomorrow so you can dismantle it with confidence.
PS - PM me your address. Can't find it.
Post by dave1800 on Oct 23, 2023 0:11:16 GMT
As Jeff has noted the problem affects all 4 wheels, that seems to rule out the G valve as being the cause of the hanging as it only limits rear brake pressure. It is curious that the problem doesn't occur in reverse though all I can think is that light retardation going forward requires less foot pressure on the brake pedal than when going backwards because of the design of the rear brake shoes - clutching at straws! After all this time the G valve seals may well have deteriorated so that it no longer functions as intended so probably well worth overhauling.
It may be worth considering temporarily by passing the servo to determine whether it really is the culprit.
Post by dave1800 on Oct 23, 2023 13:03:39 GMT
Jeff, when the brakes hang after a light application, does the pedal return fully immediately. If not this points to the servo.
Post by 1800heap on Oct 23, 2023 19:45:59 GMT
It might be worth considering the master cylinder. If this is not returning properly it may be holding some pressure in the line, making it appear to be a servo problem. I would think that this type of issue would be most likely with small movements of the master cylinder piston. In other words when the return spring is at its weakest and if the piston is a bit tight.
Post by jeff on Oct 23, 2023 22:16:26 GMT
Thanks for the comments Nick and Dave, and thanks for thinking the problem through.
The pedal does return fully when releasing sharply with a clonk. I replaced the master cylinder last year with a new one but it made no difference and there is free play in the pedal before resistance is felt.
I've had quite a detailed conversation with Tony Wood having reread Dave Charter-Lea's article in the summer 23 LOCI mag. I've decided to go for an original Girling MK2 servo, and if necessary rebuild it,or have it rebuilt depending on its state. I personally don't like the feel of the Lockheed look alike, and from what I gather it can be a problematic unit, despite my efforts to correct it. Let's see what happens when I fit an original Girling MK2 unit.
As we all know, these sort of faults can often lead us along expensive garden paths into dead ends. But.... in this case, it has to be a process of time consuming elimination until the problem is eliminated. Good job I'm retired from work and have time to spare, but not so much money. The satisfaction of overcoming a problem like this in my view, is worth the cost and effort even for its entertainment value. After all, isn't that why I love a landcrab??
