Post by jeff on Sept 30, 2023 17:57:48 GMT
Hi all, hope its all going well.
Now, here's a question I'm hoping someone can answer. Does the fuel filler door/cap, seal against the metal rim of the filler neck, or does it seal against the rubber filler neck seal??
My filler neck seal, which fits like a grommet between body and filler neck is falling to bits and there is little, if any spring resistance when closing the cap.
The door flap seal looks in good order.
Jeff
Post by Penguin45 on Sept 30, 2023 23:53:43 GMT
The fuel neck comes up proud of the neck grommet, so that the fuel cap seals against the end of the metal filler tube.
I do very lovely replacements for the cap seal...
Post by jeff on Oct 1, 2023 12:19:12 GMT
Thanks Chris..it's probably sitting a bit low as the new hand made tank has to retain the old neck but is connected by a large rubber hose and clips. I should be able to adjust it
