chalkywhite
Thanks for letting me join the group, I had a Morris 1800 on a 'C' or 'D' plate back in
Post by chalkywhite on Oct 28, 2020 16:39:54 GMT
Anyone help with the A/F size of the crankshaft pulley nut please? I'm being lazy and don't fancy scrabbling on my back on cold concrete!
Many Thanks........
Post by Penguin45 on Oct 28, 2020 18:14:38 GMT
15/16". Worth trying to find a flat plate "clout" spanner as the access is rather limited.
chalkywhite
Post by chalkywhite on Oct 29, 2020 10:59:03 GMT
Thanks Chris, just need to turn engine over to set the points, mine is an auto unless there is another way? Al
Post by tonymark3 on Oct 29, 2020 18:11:37 GMT
I just take the plugs out and turn it over with the fan. Needs some pressure on the belt, but works ok.
chalkywhite
Post by chalkywhite on Oct 30, 2020 16:46:09 GMT
Cheers for that, yes can do it that way but have the dynamo assembly off at the moment & i was going to check the static timing.
Post by tonymark3 on Oct 30, 2020 18:14:17 GMT
In that case maybe wrap a cord or thin rope around pulley at least twice and you should get enough purchase to move it. Worth a try.
Post by Penguin45 on Oct 30, 2020 19:05:23 GMT
Stick it in gear and push?
chalkywhite
Post by chalkywhite on Oct 31, 2020 15:40:49 GMT
Difficult with an automatic, if life was that simple!
Post by Penguin45 on Oct 31, 2020 17:57:45 GMT
