OKR
Sept 11, 2023 19:51:08 GMT
Post by 1800heap on Sept 11, 2023 19:51:08 GMT
HAPPY 50th BIRTHDAY OKR! I love the way the dice match the car colour. David Ah yes the fluffy dice! Added by my sister before being shipped. Tragedy is I think fluffy dice are illegal here! Nick
OKR
Sept 29, 2023 20:42:48 GMT
Post by 1800heap on Sept 29, 2023 20:42:48 GMT
I am still plugging away at it. My to do list has not got any shorter! Actually, it's a bit longer! Most of last week I was messing around getting the rear wing arch profile right which I finished yesterday. Even though the arch metalwork turned out quite nice considering, any tiny little wobble will show in the topcoat, so I have given it quite a bit of attention with the body filler and sanding block. So, I am now working on the rear paint finally! I have removed the quarter-light window and noted the rubber hinges are nasty. An email to Tony and he has some alternative rubbers, which require a small mod to the body. I have ordered a set as of today as a backup but decided that I may try to 3D print a set. Yes, 3D print! I had considered trying to con Chris into having a go at making the rubbers. It is a nasty piece to cast though. I made an interesting discovery recently though. A rubber filament is now being used called TPU. It is a type of printable polyurethane. Who knew! Using the best old rubber, which as you can see is in a bit of a state, I now have a Cad drawing after some work in front of the laptop. I have also ordered a reel of TPU so I will let you know how I go. Surprisingly the old rubber is good enough to get the measurements from. I have a bit of an advantage because the BL designers liked neat imperial measurements. What I mean is for example the hinge slot measures roughly an inch on the old part, so it is highly likely that the measurement on the original drawing was an inch. As with all the other measurements, which were all kind of close to fractions of an inch. This is very helpful in determining the proper sizes for the part. Slowly but surely, I am getting there! Nick
OKR
Sept 30, 2023 8:04:54 GMT
Post by Penguin45 on Sept 30, 2023 8:04:54 GMT
Detail, detail, detail. That's where so much time can go.
Yes, Tony is sending me a sample to see if it can be moulded...
OKR
Sept 30, 2023 9:41:16 GMT
Post by 1800heap on Sept 30, 2023 9:41:16 GMT
Yes so many little things that take time Chris! Looking at the cad model it's going to be tricky to cast, from my very limited knowledge of casting. I did send Tony my drawings and an .stl file, which is a file that can be sliced to do a 3d print of the part. If they are helpful to you I will email them. There is a cad feature which alows me to subtract the part from say a block and get a negative. I wondered if it would be possible to 3d print the negative mould or at least the hard parts of it. Anyway if I can help with anything let me know. Nick Detail, detail, detail. That's where so much time can go. Yes, Tony is sending me a sample to see if it can be moulded... C.
OKR
Oct 1, 2023 17:18:47 GMT
Post by Penguin45 on Oct 1, 2023 17:18:47 GMT
Window Pivot Rubber by Penguin 45, on Flickr Dat's wot e's talkin' about. Lovely tech file arrived all the way from Oz. Tomorrow I'll try and make the tongue insert and see if I can make a mould. C.
OKR
Oct 1, 2023 21:18:22 GMT
Post by 1800heap on Oct 1, 2023 21:18:22 GMT
Nice job Chris Looks great. Putting the milling machine to good use by the looks. I only just sent the plans! Awesome! Nick Window Pivot Rubber by Penguin 45, on Flickr Dat's wot e's talkin' about. Lovely tech file arrived all the way from Oz. Tomorrow I'll try and make the tongue insert and see if I can make a mould. C.
OKR
Oct 6, 2023 19:30:53 GMT
Post by Penguin45 on Oct 6, 2023 19:30:53 GMT
Window Pivot Rubber by Penguin 45, on Flickr Tongue part made. Suitable base for mould found, so should be able to assemble that tomorrow and see about a couple of test pieces. Chris.
OKR
Oct 6, 2023 19:53:16 GMT
Post by 1800heap on Oct 6, 2023 19:53:16 GMT
Looking good Chris. Hopefully the moulding goes well. Nick Window Pivot Rubber by Penguin 45, on Flickr Tongue part made. Suitable base for mould found, so should be able to assemble that tomorrow and see about a couple of test pieces. Chris.
OKR
Nov 4, 2023 10:03:12 GMT
Post by 1800heap on Nov 4, 2023 10:03:12 GMT
Time for an update!
I am still working on the rear paint. I have one small section to clean and undercoat. Basically the section is the sill and B post on the passenger side, plus the bit above the doors. The rest is mostly ready for topcoat with the front already done.
As it is rather expensive and I wasn't cashed up at the time I only acquired enough paint to do the front section some time ago. I broke the golden rule of getting all the paint in one hit! Sadly it has bitten me. The supplier I got the paint from is now using a different brand. Actually he says the new company took over the old one! Rather than one listing of Rover Flame Red there is now 10+ with this brand and they seem to be all different. Apparently the formulas have changed a bit too.
Sadly I didn't think to get them to label my can and this has made it rather difficult to pin down which Flame Red to even test. To cut a long story short I had a rattler can made up of what looked like the closest and it is not quite a match. Grrr! I made a mistake with that too. I should have got a small pot, which would have been easier, cheaper and they could have darkend it a bit for me with some more black. Can't do that with a can. Oh well. I also cannot get police white here at all, which is the roof colour. An all round pain in the bum really.
Good news for cash flow and bad news for the car, I am now working full time. The time I can spend on the car has been severely limited though, luckily most of the hard work is done.
Hopefully I can get over these last couple of hurdles and finish the paint in the next couple of weekends. With any luck tomorrow I can get them to crack the red paint colour after this first attempt.
OKR
Nov 5, 2023 0:06:56 GMT
Post by dave1800 on Nov 5, 2023 0:06:56 GMT
Hi Nick
That is so frustrating. I hope they are able to sort out the right colour. Where does that leave trying to match the roof?
OKR
Nov 5, 2023 21:02:14 GMT
Post by 1800heap on Nov 5, 2023 21:02:14 GMT
Hi David The paint guy got a good match with a 10ml sample he made up by altering one of the flame red choices. I was happy with it, so I had him make up a rattler can. Unfortunately it didn't scale well as was a little light when I tested it. The only mod he did was adding extra black, so I think it just needed a little more black. In a 10ml sample that's not a lot of extra black so I think the larger quantity just needed a bit more than he calculated. I have to go back and see him again. With the roof I have two choices. Respray the lot in a different white or take the car and have them scan it. The latter is probably what I will do so the roof will have to wait till the car is on the road. Nick Hi Nick That is so frustrating. I hope they are able to sort out the right colour. Where does that leave trying to match the roof? David
OKR
Jan 9, 2024 17:11:31 GMT
Post by andrewa on Jan 9, 2024 17:11:31 GMT
Either a lot has happened at your end or you've been too busy with work and relaxing at the beach..... Cheers
OKR
Jan 10, 2024 9:03:54 GMT
Post by 1800heap on Jan 10, 2024 9:03:54 GMT
Hi Andrew Bang on except for the beach part! New full time job and too many other things happening, including the daily driver popping a cylinder head core plug, which I really didn't need! OKR is still progressing though, all be it back to very slowly. It is looking likely to be a year late on the target date at this rate. Although I actually don't have that much more to do so hopefully not! The weather here has not been great for progress with the paintwork. Too much rain about, so I have been working on the rear bumper. Bit of sand blasting, because it's going to be black instead of chrome. It hasn't had bumpers fitted for a long time but I don't want to deal with too many things in the compliance check. I have decided to go with a front seat mod. There is a headrest requirement here in Australia for 73 cars. New seats I hope will be the best option. Hopefully they will be happy with my one piece adaptor plate. Yet to be made! Undecided what to do up front yet. Anyway once I have done the rear bumper and brackets I will do a proper update. Nick Either a lot has happened at your end or you've been too busy with work and relaxing at the beach..... Cheers Andrew
OKR
Jan 10, 2024 10:40:27 GMT
Post by andrewa on Jan 10, 2024 10:40:27 GMT
Good to hear....lots happening on Bristol but have farmed it out to excellent new chap, whilst I concentrate on mini boat project...it's made of ABS (the boat) so am learning the mysteries of that which is interesting. Look forward to update in due course . All the best Andrew
OKR
Jan 10, 2024 19:51:43 GMT
Post by 1800heap on Jan 10, 2024 19:51:43 GMT
Mini boat made of plastic sounds interesting. There is a company here in town that make plastic boats called Polycraft. They are slightly heavy but otherwise excellent. I use one occasionally for rowing. It is a Tuffy 300, its super stable and extremely difficult to sink apparently. I believe they make them from polyethylene. The same parent company make plastic trailers and big plastic water tanks. Quite innovative really. So the Bristol is off the road at the moment? Nick Good to hear....lots happening on Bristol but have farmed it out to excellent new chap, whilst I concentrate on mini boat project...it's made of ABS (the boat) so am learning the mysteries of that which is interesting. Look forward to update in due course . All the best Andrew
