Post by tandem on Sept 30, 2019 2:50:19 GMT
hi all i have an austaloy pump and one of the valves on the pressure has given up the ghost there is a rubber washer has broken down in the saunders valve can any ome help in this matter regards tandem (ross)
Post by Penguin45 on Sept 30, 2019 23:08:06 GMT
Hi Ross, Can't answer the question directly, as I imagine your Oz pump will differ from our Churchill one. What will be worth doing is following THIS LINK to Tony Cripps newsletters. They're a great read in their own right, but three of them detail the construction of a hydrolastic pump from first principles, complete with how to make all valves and diaphragms. Hopefully you can work it out from there. Chris.
Post by tandem on Oct 1, 2019 0:20:19 GMT
hi Chris my pump is a copy of the Churchill and should have the same components i think regards Ross
Post by tandem on Oct 3, 2019 20:11:40 GMT
spare parts found and on way
Post by paddymk2 on Oct 18, 2019 1:53:47 GMT
Hi Ross - where did you find the parts? Paddy
