Post by paddymk2 on Aug 27, 2019 13:59:37 GMT
Hi Again, many of the cars I've seen have rust at the bottom of the doors. After its cut out and repaired by your favourite method - what stop it coming back and turning the $$$$ new paint job sour? - Other than never washing or getting caught in the rain.
rusty doors.pdf (30.23 KB) Cheers Paddy
Post by snoopy11 on Aug 27, 2019 16:13:16 GMT
Rusty doors is easy.
Beg Mr P to look at it. He will prod with his rust attracting screw driver. Threaten the door with a cutting wheel Chant a mythological rust banishing spell (bstrd, ball cocks or something like that) Squirt magical gunk Wave his welder wand whilst wearing head dress passed from one rust doctor to the next New metal will then appear and you collect the doors later
In answer to you question I’ve no idea but use good quality products. I’m sure Mr P will be along soon to give you a proper answer with what he uses.
Post by Penguin45 on Aug 27, 2019 18:53:22 GMT
Two reasons. The door weather seals don't work and the drain holes along the underside of the door get blocked. Door retains water, door rots out.
As Snoopy eloquently described it, chopping off the bottom 3" of the door skin, repairing the bottom section and fitting a new skin section is the only proper way of dealing with it. Then, clear the drain holes and after the doors have been painted, shoot in lots and lots of cavity wax.
Post by paddymk2 on Aug 28, 2019 3:04:31 GMT
Thanks - that make sense and will avoid a lot of grief! Paddy
