Post by broncoza on Aug 28, 2018 9:51:26 GMT
Hi all, I am battling to obtain front seals for the hub after having sourced new bearings. Does anyone have alternate part numbers I can try and source locally before doing the eBay thing.
Thank you
Post by dave1800 on Aug 29, 2018 6:22:25 GMT
Try sending a PM to Ken (cptkennykidna) I know he has done quite a lot of research into wheel bearings in Australia and may have an alternative part number that you may be able to source locally in RSA. You can also contact Tony Wood (see landcrab.net), he gives preference to LOCI members and I recommend joining if you aren't already signed up.
Post by Penguin45 on Aug 29, 2018 19:50:57 GMT
Try Quinton Hazel GHS175 or Payen NB290 for front inner and Payen NB277 for the outer. I think they are the later ones. Full parts listing is available through a link in the Documents section - HERE. Chris.
Post by Penguin45 on Aug 29, 2018 20:07:30 GMT
