Post by andrewa on Jan 30, 2019 19:47:02 GMT
Post by paddymk2 on Jan 31, 2019 7:52:23 GMT
Thanks Andrew, I'm in Adelaide so that fella is just up the road. He did do some work on the car earlier - is very helpful. He'd couldn't recommend repairing the transmission due to cost. Suggested swapping out to a manual box but its still costly. Even had a possible donor car. Weighing up my options - getting back to the gardening while I think. All British Day is up soon - so there might be some sources to tap there.
Cheers Paddy
Post by andrewa on Jan 31, 2019 10:42:27 GMT
Good hunting. If you end up buying one of the cars with a solid sun visor am happy to bid you for the visor! Have fun in the garden - me have minus 2 Celsius at the mo - expect you're a bit warmer! Cheers Andrew
Post by paddymk2 on Feb 2, 2019 3:16:07 GMT
Thanks Andrew, Wrecker offered a manual for $375. I need to talk to my mechanic pal but I.m estimating a solid days work. Of course with something like that you never know the condition. The car at the Austin parts supply was running and could be driven but was a bit much for the project.
Yep was another record 46oC the other week - has cooled to a passable 37 today. I miss the cold and the rain - never thought I'd say that. Cheers Paddy
Post by dave1800 on Feb 2, 2019 12:49:32 GMT
Anything over 40C and I can't think straight and certainly not conducive for working on the car! To take out the engine and autobox and convert it to a manual I would allow 3 whole days but an experienced mechanic with all the gear may do it faster. Apart from the obvious addition of a clutch pedal and cylinders there are a lot of gaskets to clean between the engine and adapter plate and not something that should be rushed if you want to avoid oil leaks. I used to reckon on 6 hours to change the clutch including removal and reinstallation of the lump when I was younger!
Post by andrewa on Feb 2, 2019 15:18:30 GMT
Can't remember - or perhaps you didn't tell us - how good the rest of the car is, which will sort of determine how much is worth investing? I reckon it's either patience or just bite the bullet and get it done by the mush that knows the car. You've got Austins over Australia and the Bay to Birdwood coming up later so you need an Austin and hopefully you'll be getting over/have forgotten the cost by then! My turn to head into the garden now...it's a biting north westerly and barely above freezing but we're having swimming pool filled and have to sort electrics (not my strong suit!). This is us www.bbc.co.uk/weather/2642533We're by the sea down south and it has never got this cold before as far as I can remember! Brrr
Post by dave1800 on Feb 3, 2019 1:14:15 GMT
I still remember 1963 in the Midlands, the overnight temperatures were around -5 to -10C for around two months and on a good day it could reach as high as -2C. Snow remained in the fields until March. After a while it wasn't too bad, but then I was a young teenager.
Post by andrewa on Feb 3, 2019 16:48:40 GMT
And I wasn't born until a year later!!
Post by dave1800 on Feb 4, 2019 2:02:56 GMT
Yes, 1964 the year that the Beatles first toured the USA, Crabs first emerged on UK roads the birth of Andrew A. I remember it well! David And I wasn't born until a year later!!
Post by paddymk2 on Jun 10, 2019 13:23:27 GMT
Just a bit of an update. (Auto gearbox slipping into 1 & 2) I'd been kind of convinced that the only thing to do was to swap over to a manual gearbox. I kept looking for a suitable donor car but nothing appeared (within 500km). A couple of other options were a good autobox (easier but rarer).
I've sussed out another few shops that are able to work on the transmission. And talking with my mate was persuaded to consider attempting something myself. - If I'm going to replace the box why not have a try to replace the clutches(?)
The Eighteenhundred has the full service manual for the gearbox. And the BL manual is very comprehensive on the autobox. Looking through it made me realise that the L modes and the D modes are indeed reliant on some different components.
Thus it was time for a test run around the reservoir. And yes! Starting in L till about 15MPH and then moving to D seems to work. I've got to do some more extended tests. But even starting at the lights on the steep hills it just seemed to pull away nicely.
There's more to do - if it is as simple as a single worn component then I should be able to identify. On the other-hand the flow through the hydraulic circuits might only need a nudge to work - or not work.
Still I'm stoke to pull out onto the main road without the wobble-shuffles!
Post by andrewa on Jun 10, 2019 14:15:09 GMT
Excellent news - well done for persevering !
Post by dave1800 on Jun 10, 2019 19:02:45 GMT
Please keep us informed, I'm learning about the mysteries of automatics from you as I imagine are others here.
