Post by dave1800 on Mar 8, 2018 3:10:37 GMT
Some of you may be surprised by the results of this comparison of the importance of ignition timing as compared to the fuel mixture in this video when looking at power output. HereYou can jump to 2 mins 30 secs on the video to just see the results. Although this was done on a fuel injected Honda there is no reason to believe a similar result would not be obtained with a crab engine - although probably needing to shift the air fuel ratios lower ( ie a greater % age of fuel : air ). May be of greater interest to our resident distributor specialist - Chris - and those with tuned engines. David
Post by Penguin45 on Mar 8, 2018 18:19:40 GMT
Interesting. All in the future at the moment. I want to get a distributor which I know to be correct fitted, then we can start looking at things properly.
