Post by stoneme on Feb 26, 2018 17:42:22 GMT
Hi All, I`m trying to find the part number for a fuel tank sender unit ?? It probably also will fit other cars but I have no idea, Also, Engine mounts, and and all of them ?? 1974 ish Austin 1800 Any help please, I`ll remember you in my Will
Post by Penguin45 on Feb 26, 2018 19:15:45 GMT
Welcome aboard, Stoneme. Fuel sender is ARA974. If you don't want to pay the larcenous £95 for the one on eBay at the moment, the MGA (I think....) sender can be tweaked to fit. Engine mounts. Front: 11H 1648 Rear : 11H 1643 End: 11H 1610 Bear in mind that Tony Wood supplies uprated versions of these. The end mount particularly is far superior to the rubber block. Therefore, you should seriously consider joining LOCI to access Tony's Emporium. spareathought[AT]landcrab[DOT]net will get you in touch. The full parts listings are available to plough through HERE. Chris.
Post by dave1800 on Feb 27, 2018 1:03:00 GMT
If the fuel tank sender problem is that it is open circuit, it may be possible to repair the break in the resistance wire using solder - I managed this successfully many years ago.
