Doors
Apr 9, 2017 16:45:36 GMT
Post by landcrabman on Apr 9, 2017 16:45:36 GMT
Can anybody help . After hanging a new rear door the gap between the front door and the rear one is a little wide the front one is ok and the old rear door was ok gap wise , as you will know there's up and down and in and out , is there any tricks to make it better. Thanks
Doors
Apr 9, 2017 18:33:35 GMT
Post by Penguin45 on Apr 9, 2017 18:33:35 GMT
The "old" doors fitted reasonably well and as you know there is is only vertical and horizontal adjustment, therefore the change in fit must be down to the shape of the frame of the new door. To close the gap at the bottom you would have to knock the inner frame inwards using a hammer and a block of wood - slowly, gently and check for fit very regularly!
Doors
Apr 9, 2017 19:13:31 GMT
Post by landcrabman on Apr 9, 2017 19:13:31 GMT
The "old" doors fitted reasonably well and as you know there is is only vertical and horizontal adjustment, therefore the change in fit must be down to the shape of the frame of the new door. To close the gap at the bottom you would have to knock the inner frame inwards using a hammer and a block of wood - slowly, gently and check for fit very regularly! Chris. Thanks chris that the conclusion I came to , cracked on this weekend with the fine weather so getting there .
Doors
Apr 10, 2017 7:30:25 GMT
Post by tommydp on Apr 10, 2017 7:30:25 GMT
I made some shims to go behind the door hinges, to adjust the gap. Worked very well.
Doors
Apr 10, 2017 20:47:11 GMT
Post by landcrabman on Apr 10, 2017 20:47:11 GMT
I made some shims to go behind the door hinges, to adjust the gap. Worked very well. Tommy Thanks I've done that in the past but the door needs to go the other way looks like a hammer job
Doors
Apr 10, 2017 22:50:29 GMT
Post by Penguin45 on Apr 10, 2017 22:50:29 GMT
'Fraid so. Or, you could shim the front door, if it's tight to the wing and close the gap that way. Give me a shout if you want some help. Might make a nice little Sunday morning job.
