Post by dave1800 on Aug 12, 2022 3:39:30 GMT
Looking at a hybrid vehicle in a showroom recently I noticed the spec of the petrol engine was on the face of it quite similar to the 1800S. (Source of data Toyota and BMC/BL). 1800S Toyota C-HR Capacity 1798c 1798cc Bore 80.26mm 80.5mm Stroke 88.90mm 88.3mm Power 96bhp @ 5700 rpm 98 bhp @ 5200 rpm Torque 106ft lbs @ 3000 rpm 104 ft lbs @ 3600 rpm CR 9.5:1 13.0:1 The Toyota engine bore and stroke dimensions are clearly governed by the need to keep it narrow to fit the electric motor and associated electronics under the bonnet but also reflect the fact that these bore/ stroke ratios are reported as being close to ideal for economy. The Toyota engine also uses a simulated Atkinson cycle to improve fuel economy hence the high CR. At first sight it appears not much has improved in 60 years in terms of power despite all the computer modules, sensors and maze of wires but that of course is only part of the story but it does make you wonder! David
Post by Penguin45 on Aug 12, 2022 23:22:04 GMT
Interesting. It's been commented on here more than once the surprising economy of our engine on a decent run. No doubt the Toyota engine is oil tight though.
Post by dave1800 on Aug 14, 2022 0:02:45 GMT
And another little gem - source Motor magazine October 1964. Note the specific fuel consumption is low from 2000-4000rpm. (Click the pic and login to read it!) David Interesting. It's been commented on here more than once the surprising economy of our engine on a decent run. No doubt the Toyota engine is oil tight though. Chris.
