Post by dave1800 on Nov 23, 2014 4:49:14 GMT
There will be a time that it will be essential unless the developments with 3D printing enable displacers to be produced again - not as far fetched as it sounds if you look at Youtube videos. I see Minis are being converted to coil springs but the interconnected suspension on the crab is so much part of its unique character. Air ride? Sounds promising. David [/a][/quote]As as a wild thought. If we are looking at retro fitting other components for suspension fixes why not consider air ride. Should be relatively simple as it can't back a lot different. [/quote]
Post by threelitre on Nov 23, 2014 22:43:24 GMT
Well, here is a text I wrote for the ADO16 club magazine - I think the future of Hydrolastic and Hydragas cars will be to keep interconnected suspension! At least mine will do...
------------------------ The future of Hydrolastic suspension
All owners of Hydrolastic-sprung cars certainly know the big advantages these suspensions give to the ride and handling of the cars. But many will by now also know the downside. Due to the age of the systems, failures of spring units start to get more often. Bear in mind, that nearly all Hydrolastic units are now older then 40 years! Quite impressive for a highly loaded piece of rubber, which forms the spring in these cars.
Keep it or replace it?
It cannot be denied that modern standard steel spring and damper suspension have come a long way since the 60s and do work very well. And computations can help to adjust the rates close to getting perfect even before the first test drive. With this in mind, the question should be allowed, if a replacement made of standard springs and dampers cannot be made. Of course this is possible and has already been done to my knowledge to at least one 1300 and one Austin Allegro. And there are – of course – kits available to replace the rubber springs in Minis and Hydragas on the MGF. But this requires quite a bit of effort and specifically made parts, so it will be quite expensive.
So why not try to keep Hydrolastic? There will be a day, one day, when no original unit will be in working condition anymore. It is already getting more and more difficult to get hold of good working ones. New ones out of the box are a rarity since a couple of years. Due to the great resilience of the units in the first place, the amount of spares produced was quite small. On the other hand, there are good reasons to think about ways to keep Hydrolastic working. For one it was one of the defining features of the ADO16, so an important part of keeping one of these in original condition to preserve as a classic. On the other hand the ride experienced with Hydrolastic cannot be replicated with a conventional setup. The reason is, that both spring rates and damping rates are highly progressive, both increasing with the load of the car in a way that the car 'feels' roughly the same, independant of the load. And this is before getting the interconnection of the units on each side into play. Today similar effects are achieved using very sophisticated computerised adaptive damping and anti-roll systems.
The late Dr. Alex Moulton was well aware of the problems owners of cars with 'his' suspension system may have in the future, as well as some shortcomings particular in the ADO16. During a couple of meetings over the past 10 years he has shown me a possible solution.
There are generally 3 problems arising with Hydrolastic units:
1) The lower diaphragm, which houses the push-rod with the cone may split. In many cases a damage of this membranes can occur if there is dirt or corrosion trapped between the cone and the rubber. If a unit is out of the car, it is adviseable to clean this area.
2) The rubber hose attached to the units may split. This problem has already been dealt with. A new hose can be attached by using a strong clip, as is done by the Landcarb (1800) club for some time now. This is close to the way the original fitting was attached and the preferred solution for durability.
3) The rubber spring ages and may eventually burst. This is a slow process and usually shows itself in the spring 'bulging' out of the unit together with a slight degradation in ride quality over ridges or small bumps.
There is not yet a possibility to deal with problem 1), as this would not only mean to open the unit, but also to have the diaphragm remade. So trying to keep this in good shape seems necessary. As stated, failure 2 can be rectified by adding a new hose. This leads to dealing with fatigue of the rubber spring itself.
Dr. Alex Moulton has put some thought into this issue and came up with two possible solutions. The first idea was to add a flat steel-spring on the top of the Hydrolastic units, taking on the load as long as the rubber spring itself has no leaks. In some cars this idea would have lead to installation problems due to space requirements. Discussing this with contacts in the car supplying industry the conclusion is that it will actually be possible and not very expensive to remould the rubber springs, even in small series, if the metal parts were supplied. This is the key problem: Due to the needed strength re-manufacture of the steel parts seems to be prohibitive due to the cost involved. So the steel pressings would need to be re-used. The units will need to be opened and re-sealed for this kind of repair.
There are three major steel parts forming a Hydrolastic unit: One almost tube shaped piece containing the rubber spring (or rubber cheese, as Moulton called them), a 'hat' shaped part containing the damper and separating spring and displacer in the middle and last the cut-off cone containing the displacer diaphragm with the actuating rod and cone. During fabrication all three parts with all internals were put into a press and then the overlapping edge was rolled to form the rim in the centre holding all three parts firmly together. The first step, opening them, is relatively straight forward: The rolled part of the edge needs to be carefully removed. The three parts can be separated afterwards from each other for inspection and replacement of rubber parts.
Dr. Moulton came up with a solution how to close the units again. Three rings where manufactured, practically creating a kind of compression fitting held together with a large captive nut in the place where the original joint was. The ring around the spring unit needs to be split in halves to be able to be fitted, whilst the other ring and the captive nut can be slid over the unit from the displacer end. Tightening these should be done in a hydraulic press similar to the original process. Dr. Moulton actually has had a prototype made and put it into a test bed to check the unit after refitting successfully.
So right now the plan is laid how Hydrolastic units can be partially refurbished. The rubber internals and the connection hose can be renewed using the method described above. Also the possibility of combining intact parts of units to a working one is given. As the damper valves are also accessible when the unit is dismantled, these can also be renewed or even modified to address the weakness of the installation in the ADO16.
Right now it would be worth considering that the club, or individual members, collect all Hydrolastic units, even those with defects. Dr. Moulton advised us not to throw any of them away to secure the future use. They might - apart from directly keeping cars on the road with intact units - be a valuable source of spares for the reconditioning process of Hydrolastic units.
Post by dave1800 on Nov 23, 2014 23:51:55 GMT
Thank you for posting a copy of your excellent ADO16 hydrolastic displacer article. This sets out very clearly the opportunities for keeping the displacers functioning for many more years as long as certain precautions are taken.
Perhaps there is an opportunity for LOCI and the ADO 16 club to explore jointly the options for remanufacturing internal metal components and also replacing the rubber in light of Sir Alex' comments. Have you ever discussed this with Tony Wood or others?
Post by threelitre on Nov 24, 2014 0:28:20 GMT
Indeed, when I was on the phone with Tony Wood regarding some spares, this topic was discusses already some time ago. Alex Moulton's test dates back to 2006, when he did show me the results and also handed me the copy of a drawing showing the pieces manufactured to refit the body. A similar discussion recently happened on the Princess (wedge) forum, where I proposed a similar approach. I think it is safe to assume that any kind of re-manufacture keeping the original steel parts will be cheaper than all possible repacements with a completly different system of springs and dampers.
Post by Penguin45 on Nov 24, 2014 0:39:21 GMT
Very intersting, Alexander. Curious to note that there is a hydragas solution already available for the MGF. No doubt they have the advantage of far greater numbers than our cars, so production is a viable option. HERE. This makes the cars' suspension fully independant rather than linked, but seems to be a well thought out and obviously working solution. Chris.
Post by indianajones on Nov 24, 2014 7:37:12 GMT
Oh well that's a shame, thanks Peter I must have been reading old info on the net. That news won't please Andrew in NZ. Hah. I did recall reading that fact somewhere, but that Hydragas displacers can be serviced a bit better than Hydrolastic ones (i.e. last longer) -Andrew
Post by dave1800 on Nov 24, 2014 13:11:37 GMT
Have you thought about sending a copy of your article to Michael S at LOCI. I believe it would make interesting reading for all Landcrab owners and may stimulate some further investigation or action. It would also reinforce the message not to dispose of any displacers when they fail. Regards David Indeed, when I was on the phone with Tony Wood regarding some spares, this topic was discusses already some time ago. Alex Moulton's test dates back to 2006, when he did show me the results and also handed me the copy of a drawing showing the pieces manufactured to refit the body. A similar discussion recently happened on the Princess (wedge) forum, where I proposed a similar approach. I think it is safe to assume that any kind of re-manufacture keeping the original steel parts will be cheaper than all possible repacements with a completly different system of springs and dampers. Regards, Alexander
Post by indianajones on Nov 24, 2014 18:58:34 GMT
It would also reinforce the message not to dispose of any displacers when they fail. Agreed, that's the key message here. Just need to convince our wives it's for the greater good! -Andrew
Post by threelitre on Nov 24, 2014 21:22:00 GMT
My intention is to have the article published in the other relevant club magazines - it seems it is time to do so now.
I do know about the MGF solution... BUT: This solution has a number of (big) flaws. In many coutries it is not legal, as necessary engineering reports (costing some thousends of Euros/Pounds Sterling) are missing - I hear it should be legal for Germany soon. It also puts too much stress on the MGF's shock absorber mounts, with a few cases of cracked bodywork already having appeared. Possible OK for a sports car, but for a saloon car it would be very difficult or impossible to ge a useful amount of progression into these springs. I know of an ADO 16 that was converted with a very highly engineered solution (very expensive too) - and of course it is possible to have springs and shock absorbers made to measure. But I am pretty sure that it will be less expensive to manage a small scale reconditioning job for Hydrolastic units compared to a properly engineered steel suspension. On top of keeping an integral part of the car's engineering alive.
Hydragas will - of course - have a similar problem occasionally. At first Hydrolastic is longer lasting, but Hydragas catches up as soon as the units are refilled and kept in that condition (I was probably not the first to do that, in fact that was Alex Moulton himself, but I was the first to publicise this and offer the service as part of my hobby).
Post by dave1800 on Nov 25, 2014 0:48:40 GMT
Tell them it's an investment for the future, like a work of art David Agreed, that's the key message here. Just need to convince our wives it's for the greater good! -Andrew[/quote]
Post by dave1800 on Nov 25, 2014 0:54:38 GMT
Alexander Any more thoughts on how to go about reconditioning? I wonder if we could turn to the Chinese for example as with the manufacture of replacement windscreens in relatively small numbers. regards David But I am pretty sure that it will be less expensive to manage a small scale reconditioning job for Hydrolastic units compared to a properly engineered steel suspension. On top of keeping an integral part of the car's engineering alive. Regards, Alexander
Post by foglaursen on Nov 25, 2014 10:19:31 GMT
I think it would be a good idea to approach the Danish company ”Nordisk Morris Minor Lager A/S” www.morrisminor.dk/default.html. Despite the name they care for many other BMC/BL cars. They already make engine mountings for the Landcrab, and I remember that several years ago they talked about remaking displacers for the 1100/1300 series. Peter
Post by dave1800 on Nov 25, 2014 12:13:21 GMT
Thanks Peter. I will forward the details to Tony Wood and others at LOCI to see if we can stimulate some interest from those holding the money!
Post by threelitre on Nov 25, 2014 18:38:15 GMT
Ideally the club should join forces with Maxi and 1100 clubs - a large part of the investment can be shared.
Post by tommydp on Nov 25, 2014 23:17:42 GMT
Ideally the club should join forces with Maxi and 1100 clubs - a large part of the investment can be shared. Regards, Alexander Good idea! I think it's wise to look into this now. It's amazing how long the displacers work, but eventually I suspect lots of them will fail in increasing numbers, and what to do then to keep the cars on the road? I think I've got five front and five rear spare displacers, so should be OK for a while. I've only once had a displacer fail. My white one has the original ones, minus one front which had failed while it was laid up (1988-2012). I would however be happy to join in and get some reproduced ones, should that become reality. It seems the Chinese can make anything, so worth a try! On the other hand I find the thought of air suspension interesting. There are different universal air spring elements available. Wouldn't it be possible to find some suitable ones which connect to the knuckle joints and are located where the displacers are? Some Range Rover ones actually look like the displacers in a way. Imagine being able to adjust the ride height, perhaps making it possible to raise the rear compared to front, in order to avoid the low rear end when loaded, so typical for these cars. Not being negative, but I got a set of those reproduced engine mountings from Nordisk Morris Minor lager once. They were very expensive and the large one split in two after 30, yes thirty, minutes.. Tommy
