Post by paddymk2 on Aug 2, 2021 13:13:06 GMT
So had to pull the carpet back at the footwell (when changing the steering rack). But now I cant push the carpet back into place at the sides at the front. Is there an easy way to remove the little trim panels (like miniature door cards), without breaking? PaddyCarpetcheers Paddy
Post by Penguin45 on Aug 2, 2021 17:07:56 GMT
If you pull the door edging off, you should be able to access the edge of the trim panel. It's held on with those pointy metal clips, so sliding a paint scraper or similar under the edge should let you pop it off.
Post by paddymk2 on Aug 3, 2021 3:01:48 GMT
Thank you Chris
