chalkywhite
Thanks for letting me join the group, I had a Morris 1800 on a 'C' or 'D' plate back in
Advice
Dec 19, 2019 19:17:33 GMT
Post by chalkywhite on Dec 19, 2019 19:17:33 GMT
As a newcomer to Landcrabs can anyone advise as to whether Power Assisted Steering is a must on an 1800 and if so can it be retrofitted? I had an 1800 back in the day on a 'C' plate and cannot remember if that had PAS or not, and I was a lot younger then! Thanks.
Advice
Dec 20, 2019 0:10:09 GMT
Post by Penguin45 on Dec 20, 2019 0:10:09 GMT
Welcome aboard, Chalkywhite,
Enjoy the forum.
Power steering was standard on the Wolseley 18/85 which appeared in 1967, and became an option on the Austins and Morrises from that point onwards. So, your early "C" reg would not have had power steering. I have driven a number of cars with p/s and have to say that I find the original set-up over-light with little "feel".
If you are looking at converting your car to p/s, the original system used a pump mounted on the back of the (special) dynamo, a pair of hoses and a power steering rack. These parts aren't particularly difficult to track down with some patience, but bear in mind that the upper suspension arms on the front were specifically p/s or non-p/s - the steering geometry is different between the two.
Late cars (MkIIIs) were alternator cars and used a separate p/s pump driven by an auxilliary belt. Some parts were shared with the following Princess, so again, most things can be found if required.
Nowadays, electric power steering can be added by specialists who add an electric motor to the steering column with some fancy electronics. These seem to be mostly sourced from Corsa cars and by all accounts work well.
From my own experience, I find that the cars are nicely balanced and weighted with manual steering once you get over a few miles an hour. They are heavy at parking speeds, but, hey, we all need the exercise!
It would be nice to see some pics of your current car when you get the opportunity.
Advice
Dec 20, 2019 7:20:41 GMT
Post by dave1800 on Dec 20, 2019 7:20:41 GMT
I believe Andrew A has electric power steering fitted to his 1800S and he can adjust the amount of assistance. It doesn't come cheap though! He does seem to run wider wheels and tyres for his rallies which would add to the steering weight and I understand it retains the feel. I agree with Chris that the hydraulic PAS fitted to Wolseley crabs as standard takes away much of the enjoyment from the feel you get from the manual rack. The MK1 cars ran 13" wheels with slightly wider tyres than the Mk11/111 and earlier ones had a lower ratio rack which lightened the steering but I think meant too much wheel twirling.
The key thing is to ensure all the ball joints are good without play or dry, the rack lubricated and the suspension geometry is correct. The bush in the lower arm can make the considerably steering heavier if it is worn.
Of note is that unlike many FWD cars where the tracking is set to toe-out the 1800 has toe-in of 1/8". It is NOT a misprint in the workshop manual and is counter intuitive to many garages experience. If set to toe-out it will increase the front tyre wear and steering weight. There are more details in the technical section including a warning about the front tie rods and checks to carry out on them.
Advice
Dec 20, 2019 7:27:48 GMT
Post by andrewa on Dec 20, 2019 7:27:48 GMT
My car didn't come with power steering and I agree with Chris that once you're rolling you don't really need it - you can always put some more air in the front tyres! However parking/manoeuvring is a pain. If you add wider wheels obviously it makes it worse. I do a bit of motorsport in mine from time to time and found it hard work - particularly up and down mountain passes (!)- so went with an electric system which has transformed the driving experience for me. You can vary the level of assistance easily just by turning a knob - so full assistance for car parks, next to nothing for motorways and in between, the rest of the time. Cost from memory was about £1200. I learned to drive on a traditionally power assisted 1800 and agree with Chris that it seemed to me over assisted.
Cheers Andrew
Advice
Dec 20, 2019 19:01:45 GMT
Post by Penguin45 on Dec 20, 2019 19:01:45 GMT
Mr CW's current car: 1928 Humber 9/20 by Penguin 45, on Flickr Beautiful 1928 Humber 9/20. Al tells me that once this sells, he'll be finding himself a 'Crab. It's for sale on Car And Classic for those interested. Chris.
Post by dave1800 on Dec 22, 2019 1:32:25 GMT
Interesting that you can vary the assistance on the fly. Is it a series of pre-set or constantly variable settings? If the latter do you find it hard to adjust to the new weight, a bit like going from a manual to PAS and oversteering at first? Maybe not an issue for a seasoned rally driver such as yourself but for us mere mortals? When I owner an 18/85 I researched whether the PAS pump could be operated through an aircon compressor type of clutch just to engage at parking speeds but sold it on before I got round to it. On reflection I think it would have required more than that. Back in 1971 I hired a crab in Kent from a well known company which seemed to have slightly heavy steering from the start and drove it to Worcestershire before discovering it did in fact have PAS but the reservoir was empty! David My car didn't come with power steering and I agree with Chris that once you're rolling you don't really need it - you can always put some more air in the front tyres! However parking/manoeuvring is a pain. If you add wider wheels obviously it makes it worse. I do a bit of motorsport in mine from time to time and found it hard work - particularly up and down mountain passes (!)- so went with an electric system which has transformed the driving experience for me. You can vary the level of assistance easily just by turning a knob - so full assistance for car parks, next to nothing for motorways and in between, the rest of the time. Cost from memory was about £1200. I learned to drive on a traditionally power assisted 1800 and agree with Chris that it seemed to me over assisted. Cheers Andrew
Advice
Dec 22, 2019 22:48:27 GMT
Post by andrewa on Dec 22, 2019 22:48:27 GMT
It's not constantly variable, by which I mean it's not speed sensitive. You just turn the knob to what you want! 99% of the time it's in the middle...but you just turn it to what suits....it works brilliantly and if it fails you just have normal steering. Cheers A
