Post by tonymark3 on Aug 28, 2020 13:53:21 GMT
Hi David. Comments agreed. Have rechecked timing and set strobe to 10 degrees BTDC vacuum blocked off. Ticks over nicely at 6 to 700 rpm. Checked carb jet tube height and wound up one flat and stalls. Wound back one flat and momentary hesitation and then resumes normal tickover so shall leave at that. Peter Burgess says that will run slightly richer due gas flowed ports but OK to use standard filter and ignition settings. When the rain stops will give it a run.
Post by tonymark3 on Sept 8, 2020 18:20:23 GMT
Tidied up painted stripes today. Was a bit worried as small ridges of paint where edge of masking tape stuck. Tried a couple of things to rub down slightly. best result came from rubbing along stripes with white spirit on a rag , then buffing up. Cleaned off tape residue and paint high spots. No doubt as it gets successive clean and polishes it will adopt the slightly worn look.
Post by Penguin45 on Sept 8, 2020 18:53:48 GMT
Hang on! Yours is supposed to be mint - mine's supposed to the one with the worn look.... Chris.
Post by tonymark3 on Sept 8, 2020 20:30:50 GMT
Now you know they will never be perfect. Always leave something for the rivet counters. Saying that, I hadn’t the heart to drill holes in my new Cills so the kickplates went on with double sided tape. Someone will castigate me for the missing rivets!
Post by Penguin45 on Sept 9, 2020 20:28:25 GMT
Sounds a perfectly reasonable solution to me.
Post by tonymark3 on Sept 16, 2020 16:32:08 GMT
Decided to resurrect the old mud flaps as couldn’t really find suitable ones. A good scrub and a wipe with a thinners rag and i think they will do the job. Saw a set of GAC 166 which i think were the right ones on eBay . Cheeky g%t had them advertised at £95. I dont think so.......... B46ED105-C405-4ADD-8097-639A116F0818 by Anthony Surman, on Flickr Tony S
Post by Penguin45 on Sept 16, 2020 17:30:09 GMT
There are lots of chancers on eBay. I SAY DING DONG will probably have some new stickers to suit those flaps. Fun site - repro stickers and decals for just about everything. C.
Post by tonymark3 on Sept 16, 2020 18:47:17 GMT
I shall have a look. Ta.
Post by tonymark3 on Sept 18, 2020 14:01:01 GMT
Post by Penguin45 on Sept 18, 2020 17:22:29 GMT
Pleasure. I'm fairly sure they're quite mad. Those look the business though.
Post by tonymark3 on Dec 2, 2020 20:25:37 GMT
Timely reminder with the damp weather. Went round to the garage to give the old gal a run. Back brakes stuck. Must remember to leave it in gear and handbrake off. As it’s all new brakes I couldn’t get as much clearance as I would like. Must do some heavy braking! All ok after a little run.
Post by tonymark3 on Dec 5, 2020 19:40:26 GMT
Post by Penguin45 on Dec 6, 2020 9:37:43 GMT
If it works, don't knock it.
Been absolutely bitter up here - snow on top of Pendle Hill and that's only a coule of miles away.
Post by tonymark3 on Feb 2, 2021 18:14:24 GMT
Spent the afternoon installing rear seat belts. Instructions of the boss. Just over £90 for set of two inertia and one lap belt, not too bad. only hiccup was one of the weld nuts wasn’t tapped. Good old BMC. Didn’t even know I’d got a 7/16 UNF tap so a pleasant surprise. Interesting that brand new kits still come with UNF fittings.
Another lesson learnt today was don’t leave the car too long between runs. Clutch was stuck to the flywheel. Eventually freed after starting in first gear and clutch and brake at same time. Feathered clutch a bit after that to hopefully clean up the faces.
Post by tonymark3 on Mar 23, 2021 12:18:19 GMT
I have just purchased a new harmonic balancer as the one on my motor may have gone hard after nearly fifty years. After searching i found that www.abingdonmgparts.co.uk/product/pulley-timing-marks%3A--mgb-1800/12h963 had new ones for £74 delivered. Not cheap but compared to some at £200 plus out there I think something of a bargain. Comes with both sets of timing marks. Tony S
