Post by wolseley on Mar 8, 2019 14:22:44 GMT
Hi All
Im on the look out for a 3 branch manifold and Y piece
Many Thanks
Post by Penguin45 on Mar 8, 2019 18:08:44 GMT
The only one I'm aware of is from Maniflow - HERE. Chris.
Post by snoopy11 on Mar 9, 2019 17:20:20 GMT
The only one I'm aware of is from Maniflow - HERE. Chris. Eeekkk That’s a lot of money.
Post by steve4487 on Mar 9, 2019 18:07:17 GMT
I've fitted one of these manifolds on my last Morris S. I found the curve of the centre branch is not as sharp which means the centre branch runs closer to the carb float chambers, this resulted in the fuel boiling. To get round this issue I used insulated spacers with longer carb studs which moved the float chambers just far enough away to stop the fuel boiling.
Steve
Post by andrewa on Mar 9, 2019 23:14:21 GMT
I did the same - worked a treat.
Cheers A
Post by deconstruction on Mar 14, 2019 13:40:15 GMT
Very nice piece of work: And Maniflow also offers a compatible exhaust system: Although that little transverse silencer / resonator looks a bit odd. I know someone who uses two RC40 silencers on his 18/85 S (no spare wheel tray, spare wheel in the boot). Works and sounds fine.
Post by andrewa on Mar 14, 2019 13:54:17 GMT
Yes - went for the whole set up - without the bean can silencer to start with - it sounded great (well it sounded like a rally car should) - but did irritate on long drives as was very boomy. The little extra can - much to my amazement - made a huge difference in boom reduction when I had that fitted and no noticeable effect on performance.
