Post by Keef on Sept 23, 2018 7:28:25 GMT
And yet another saved and added to the fleet! image by keef, on Flickr
Post by Keef on Sept 23, 2018 7:35:20 GMT
A good wash and polish (the first in over 20 years!) always helps. image by keef, on Flickr
Post by rosieuk on Sept 27, 2018 17:04:10 GMT
Doesn't look to be in bad nick. Good luck with it.
Post by Keef on Oct 7, 2018 18:33:29 GMT
Just replaced a front displacer that gave up as I was pumping up the suspension, but apart from that and loads of surface rust where stone chips etc. have let the moisture under the paint.......
Post by rosieuk on Nov 10, 2018 13:27:37 GMT
That looks very similar to how the ADO17 is set up - are the Maxi displacers in something like that barrel structure on the ADO17? I've never been able to get my hands on a Maxi to have a look..
Post by Penguin45 on Nov 10, 2018 17:37:03 GMT
Post by Keef on Nov 11, 2018 18:09:16 GMT
The Maxi has a front subframe and the displacers are mounted across the back of the engine in this frame. The replacement displacer was from an ADO16 and I just swapped the endcup over from the failed Maxi unit. ADO17 owners will know that the ADO16 front displacer is the same as the ADO17 rear, but I was unaware that the ADO16 front is basically the same as the ADO14 front.
