Post by deconstruction on Dec 8, 2019 9:40:36 GMT
To repair an 18/85 I'm looking for some used front-end panels: a. the three small panels (1, 2 and 3 on images 1 and 2) which hold the vertical panels and the grille to the bonnet landing-panel (upper transverse member) b. repairable vertical panels left and right of the grille (4 and 5 on image 3) Quite some time ago (yes, it's a sloooow project) the wonderful Tony Wood supplied me with two new vertical panels but I would prefer not to use these (yet). As quite a lot of other metalwork is required I would prefer to re-use vertical panels cut - sympathetically - from another car. These could be rusty around the side and bottom edges but that I don't mind repairing and I have another completely intact car from which to take measurements. The small panels should be intact. Therefore, if someone is taking an otherwise unsaveable Wolseley apart, I would be very interested in these panels!
Post by deconstruction on Aug 26, 2021 19:22:29 GMT
Hope it's OK to nudge this 'up' a bit
