Post by james on Nov 11, 2019 2:25:05 GMT
Hi All, I need two Demister vents to suit my Austin 1800 Mk1 please, someone pulled to old ones out at some point in the past... are the Mk1 and Mk2 the same?? I guess yes?? Just the actual plastic bits that go from under the dash pad and then form a round tube to attach the pipe to... I should be able to get some pipe somewhere that will fit. Thanks
