wolseley1800
Attribute: The Voice of Doom!
Post by wolseley1800 on Apr 29, 2017 21:36:16 GMT
Does anyone know anything about the upper front engine tie bar shown in the parts catalogue?
Post by dave1800 on Apr 29, 2017 23:30:09 GMT
What do you need to know? I always used one on the standard crabs to reduce the torsional stress on the large engine mounting. It also limits how far the engine can drop if that mounting fails.
wolseley1800
Post by wolseley1800 on Apr 30, 2017 15:20:51 GMT
What do you need to know? I always used one on the standard crabs to reduce the torsional stress on the large engine mounting. It also limits how far the engine can drop if that mounting fails. David Basically where do they attach to the front end and are they readily available? My 'S' can without one and I believe BMC would not have gone to the exspence of designing and fitting if it was not needed.
Post by snoopy11 on Apr 30, 2017 16:42:43 GMT
This one ? Attachments:
Post by Penguin45 on Apr 30, 2017 17:44:08 GMT
Any help? Looks like the plate on the engine is extended forward, then an enclosing bracket has been added at both ends. Wasn't this also called a "Paul Cope" mounting? I think Tony Wood had something similar made before the current one using the Land Rover mountings. Chris.
wolseley1800
Post by wolseley1800 on Apr 30, 2017 20:56:15 GMT
Thanks, that helped lots
